Have 1.5 on my 12.7 Detroit rebuilt it full rebuilt turbo injectors and all except manifold was getting 7.8 whOle year didn't check in a while noticed more fuel stops checked is 5mpg I see the manifold might be leaking few spots and muffler sounds a bit clogged... you that be enough to throw it off? Did an overhead after like 50k you guys think that's all I need done? Engine sound and works without a struggle too
12.7 fuel milage help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Driveone, Feb 22, 2016.
Bad muffler could be worth. 5 mpg.
Driveone Thanks this. -
It could be the manifold however you'd have to have a major blockage to cause bad mpg there are lots of other issues such as the speed you drive at for example a vehicle running at 55 mph will get around 9 mpg subtract at least .1 per gal for every extra mph you do to get a gauge for fuel economy. Recently Peterbilt ran a road test with their new model truck loaded at 66,000 lb @ 65 mph and got 10.7 mpg.Driveone Thanks this.
I ran 70 75 getting 7.5 to 8 goING east to west the muffler sound clogged and rattles and the manifold apears to have several leaks think I'm going to change and see what it does was just planning to get input so I can do it all at once thanks guys
Truck is like my baby hate to see her hurting makes me uncomfortable
Check the intake side for boost leaks. A small one can cost you a bunch in MPGs. Really all kinds of things can suck your fuel down. The cold weather has cost me about 1 mpg.
truckerbangin and Bean Jr. Thank this.
