12v coleman cooler
Discussion in 'Millis' started by Myoneload, Sep 2, 2013.
  1. Myoneload
    Myoneload Light Load Member
    218
    45
    Jan 22, 2013
    around here
    Whats the best way to hook up a 12 v cooler? Cig lighter or to the inverter. Cig goes out when you turn off the key. But will hooked to inverter run down the batteries at night.
  3. precisionpower
    precisionpower Light Load Member
    147
    149
    Sep 8, 2011
    oshkosh wi
    Its a cooler.. it doesnt have to run constantly
  4. Myoneload
    218
    45
    Jan 22, 2013
    around here
    Will the food in it stay cold when the truck is not running? Like all nite. Im going to put milk and other drinks in it and dont wont them to spoil.
  5. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    The food will warm up when the truck catches fire due to the plug overheating.
    Old MP and luvtotruck Thank this.
  6. Suptrkr
    Suptrkr Light Load Member
    86
    45
    Aug 28, 2012
    Bentonville, AR
    There should be another 12V scocket at the foot of the bed or in onr of the closets.
  7. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    no, it won't drain the batteries overnight, best to cut off the plug and hardwire it in with a fuse and switch :thumbup:
    Hardlyevr Thanks this.
  8. SHOJim
    SHOJim Road Train Member
    3,399
    17,210
    Apr 19, 2011
    Columbus, Ohio
    Hey AW hope you are doing well out on the road!!!!!!!
  9. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    There is always a possibility if you have several things pulling off the batteries, you could run them down if stopped overnight. We had sometimes two heated blankets going when husbands volvo would sound the alarm. Don't forget trucks have so many electronics on them that run in the background. If you are at home on a reset it is better to empty it out and turn it off or hook it up to an extension cord to the house/garage. Check and see if you have a dedicated cig lighter in the back of the sleeper area that stays hot all the time vs going off when the key is off, you don't want your refrig to be off for long periods of time letting your food get hot.
  10. NavigatorWife
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    Oh and we used the inverter for things like the microwave, coffee pot. The coleman was on the 12volt and the igloo he has now is also on the 12v
  11. KF7WTV
    KF7WTV Medium Load Member
    410
    234
    Aug 8, 2012
    RENO, NV
    I was just at home for 2.5 days and left my Coleman plugged into an always-on power socket. Only when I climbed in this morning and turned the key on did the low battery (aka 'load shedding') warning go off. But the truck started right up. Granted, my ProStar+ has 8 batteries... YMMV
    And yes, if it gets real cold inside the sleeper, the cooler WILL freeze solid whatever is in it. Like a coke. What a mess. :p
