13 587 Pete Jake's work when they want to!!
Discussion in 'Ask An Owner Operator' started by missjhawk, Jan 16, 2019.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I have a 13 587 Pete I just replaced clutch 3 wks ago last week I noticed my Jake's didn't kick in then some hrs later going down hill they kicked in sometime they don't kick in when I want them 2 I keep them on high all the time so what sensor I need to replace b4 they stop all together
  3. AModelCat
    161,678
    Manual transmission? Check clutch switch. Should be somewhere on the pedal or linkage.
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,409
    7,589
    Jun 4, 2015
    Could be clutch switch, brake switch, or could be inside the transmission -- had that happen when the synchro's wore out. That wasn't cheap.... hope it's one of the switches.
  5. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    Had that problem years ago. It wouldn't do it with a mechanic around though. "Will you go to Vancouver and we will get it looked at there?" . Me"no, I'll be back at the shop in an hour drop trailer here or bring it back?"
  6. brian991219
    brian991219 Road Train Member
    3,003
    6,109
    Aug 10, 2013
    Lords Valley, PA
    Saw your other thread about your speedometer not working all the time. Did the speedo and Jake problem both begin right after having the clutch replaced? Reason I ask is some shops are lazy and take short cuts, had a clutch job done once and they stretched out my wire harness because they didn't unstrap it from my trans when they slide it back to do the clutch.
    Perhaps you have a damaged wire harness causing both problems, especially if they pulled hard on it when dropping the trans for the clutch job. Hopefully it is a simpler fix, likely they didn't readjust your clutch manual linkage after changing the clutch disc so the switch that senses clutch position isn't working properly.
    Does your cruise control still work properly? Lake and cruise circuit get their signals from the same set of sensors -brake and clutch position switches as well as the dash switches to turn on Jake. With the speedo problem you could have a bad wire harness behind the dash causing both problems, Is there any correlation between the speedo and Jake not working at the same time?
