13 and 18 speeds
Discussion in 'Experienced Truckers' Advice' started by doglover44, Jul 20, 2011.
  1. doglover44
    doglover44 Light Load Member
    191
    28
    Apr 30, 2008
    Whats the need for 13 and 18 speed trucks ? I know the most common is 10 speeds What are all those extra gears for ?
  3. Malerose
    Malerose Light Load Member
    99
    33
    Aug 13, 2009
    Medford Oregon
    OMG 13 is to die for, splitting the upper range keeps the engine in the power band only a couple of hundred rpms between splits.
    the gambler Thanks this.
  4. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    Malerose is right. I prefer 13-speed over anything else. You split the high-side gears so the RPM drop between gears is about half the normal 500 RPM.
    Now I'll get beat up by some, but I don't see the need for the 18-speed in normal hauling. The 18-speed allows you to split the lower gears too. If I were running above 100,000 pound gross then I would look at it.
    I believe progressive shifting and a 13-speed is the real ticket.
  5. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    I've found splitting the bottom is nice when your loaded heavy starting out on a steep incline....
    given the choice I want my 15 speed with the big hole against the dash back.. :biggrin_2559:
    the gambler and BigJohn54 Thank this.
  6. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Hey Bigjohn, im not going to beat you up and i agree with what you said...
    a 10 is great in the south east where there a no hills... a 13 speed IMO is perfect for the 80k trucks makes the hills more manageable and most of the time you can keep up a little more speed with it..
    im running 105 gross most of the time and i really like the 18 speed when taking off on hills in the city it makes much easier
  7. Malerose
    99
    33
    Aug 13, 2009
    Medford Oregon
    Agreee, Agreee, Agreee :biggrin_25514:
  8. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    I've got an 18. 99% of the time, I drive it like a 13. It's that last 1% of the time that I'm glad I didn't settle for a 13.
    Nothing sucks worse than trying to start out up a hill and being stuck in a low gear because the step up to the next gear is too great and you'd be lugging/stalling by the time you got it into that next gear. With the 18, I can work my way up through the gears nice & easy.
    fancypants, BigJohn54 and Smaggs Thank this.
  9. jbatmick
    jbatmick Road Train Member
    2,197
    2,499
    Dec 1, 2009
    hastings, Fl
    I have never used an 18 speed, but my favorite is a 13. Splitting those top gears comes in real handy in the hills.
  10. Injun
    Injun Road Train Member
    8,501
    9,491
    May 15, 2010
    West o' the Big Crick
    I have it on very good authority that the only difference between a 13 and an 18 is a little collar under the shift knob that falls out of the way when the selector is in high. The little collar flips back up when the selector is in low, preventing the splitter from operating.
    I would rather have a 13 than a 10 any day. The RPM spread between gears is not as severe, it's easier on the drive train, shifting is smoother and fuel economy is better. I have driven 9, 10, Super 10 and 13. I have no need for 18 because I do not haul over 80K and I do not run "off-road" hauling logs and such.
    Many of the megas run 9C (convertible to 13 or 18 ) trannies because, a 13 would be too complicated for most noobs and after they take it out of the fleet for sale, they convert it to 13 for resale value. Of course, some gears will have to be replaced after being ground to nubs by students, but only half of them.
    dirtyrabbit Thanks this.
  11. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    IIRC the gears are different ratio on the low side of the 18 versus the 13.
    L.B. Thanks this.
