13 faults HELP!!!
Discussion in 'International Forum' started by joe9246, Mar 26, 2012.
  1. joe9246
    joe9246 Bobtail Member
    23
    detroit, mi
    I have 13 faults on my 2005 9400i w/cat c13 ascert...could anyone help me out?
    102:f00 sid 003_a
    102:f00 pid 100_a
    102:f00 pid 000_a
    102:f00 sid 149_p
    102:f05 sid 003_a
    102:f05 sid 004_a
    102:f03 pid 245_p
    102:f01 pid 208_a
    102:f10 sid 003-a
    102:f13 pid 010_a
    102:f15 sid 255_p
    102:f04 sid 004_a
    102:f08 sid 025_a
  3. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    The first three numbers are an identifier of what module is sending the error code.
    128 is from the engine
    130 is from the transmission
    136 is from the ABS
    140 is from the instrument cluster
    171 is from driver info center
    219 is from collision avoidance module
    102 isn't listed.
    This is straight from our manual,
    "If any of the MIDs above are displayed on the first line of the cluster LCD, use the device software indicated to identify the fault code and obtain troubleshooting procedures. If none of the listed MIDs are displayed on the cluster LCD and there are no warning lights illuminated, disregard the fault codes and do not troubleshoot.
    Fault codes that are displayed in the cluster LCD can only be cleared with the device software indicated."
    If you have copied the fault correctly and everything is fine with your truck, no warning lights, you basically ignore them. The fault codes in the LCD display are real basic and not what we use for trouble shooting anyway.
    Auctioneer Thanks this.
  4. joe9246
    23
    detroit, mi
    Thanks for the help is ended up being the ABS wire harness, it was full of water. Dryed it out cleaned it off, put some dioeclectric grease on and viola, no more faults.
  5. Heavyd
    7,756
    6,195
    Feb 4, 2009
    Let me guess, the black round one at the firewall?
  6. joe9246
    23
    detroit, mi
    Yes sir on the firewall.
