13 KW T660 won't start with key remove breakers g2 and e2 jump wires it starts
Discussion in 'Kenworth Forum' started by DTT84, Dec 21, 2020.
  1. DTT84
    DTT84 Bobtail Member
    9
    So my 2013 kwt660 will not start with the key if I remove relays g2 and e2 use a jumper wire touch the wires on the ignition switch it will start turns off with ignition switch I've replaced the relays won't start with key the last four the VIN are 288-115 any advice is helpful I have a Volvo d13 doing the same thing
    Trucking Jobs in 30 seconds
Draft saved Draft deleted
