13 speed deep reduction options
Discussion in 'Ask An Owner Operator' started by Salted, Dec 26, 2014.
  1. Salted
    Salted Light Load Member
    96
    22
    May 23, 2014
    If your hauling stepdeck or whatever would you rather have your deep reduction on the low side or high side. Please explain your reasoning
  3. SL3406
    SL3406 Medium Load Member
    550
    1,487
    Jan 10, 2011
    Oklahoma
    You need to explain your question. A 13 speed doesn't have deep reduction.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    yeah i don't know of a 13 that has a deep reduction like a 9ll or 15, a 13 has a low gear but not really like a deep reduction.
  5. Salted
    96
    22
    May 23, 2014
    Oh then i maybe wrong. Then can someone please explain the difference between a low gear and a deep reduction gear
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    like a 9LL has a button you can switch before putting it in low gear that engages a deep reduction gear lower than low gear. this would be a deep reduction.
    a 15 is like a 10 but you can split the bottom gears like you can the top on a 13
    a 13 is like a 9 but you have a high and low option for each gear on the top side
    a 18 is like a 13 but you can split gears both top and bottom
  7. SL3406
    550
    1,487
    Jan 10, 2011
    Oklahoma
    You can't split any gears in a 15 speed. A 15 is a 10 speed with 5 lower gears when in deep reduction.
  8. Diesel Dave
    8,722
    24,984
    Jan 20, 2010
    Hesperia, Ca.
    It's lower and low gear, simply put.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    The long and the short of it is with modern diesels there's plenty of low end torque... So deep reduction is only necessary in extreme conditions aka heavy haul, soft ground very steep grades .. The last 18 speed I had was just for the torque rating to turn up engine at the factory.. IMO a 13 would've done fine
  10. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    15 is one of the few transmissions i haven't personally drove yet.
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    iv been in situations where deep reduction is very good to have. but for pulling step deck otr probably wont ever need it. id go for a 13/18 over the other options. even for what i do givin the option id go for a 13 or better yet a 18 over a 15/9LL
