13 speed splitter grinding
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chrisut, Mar 19, 2013.
  1. chrisut
    chrisut Bobtail Member
    19
    Mar 13, 2013
    I have a 13 speed is grinding from 4th to 5th on the way up.is this an easy or is this something that I will need to have someone look at. I'm hoping for an easy fix and hope it doesnt require a rebuilt transmission. any help is appreciated.
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    My Volvo did that for 7 years. I've heard it costs around $1500 to fix.
  4. chrisut
    19
    Mar 13, 2013
    I guess if it doesn't get worse I won't bother fixing it for now
  5. Hammer166
    7,553
    27,498
    Aug 18, 2007
    ~8600+' and loving it!
    It's the sychronizer for the range shift is likely going bad. It could possibly be an issue with the actuator and/or it's air system, too. Roadranger has the manuals online if you want to diagnose the problem further. Oh, and not to be a bearer of bad news, but it also possibly a bad bearing(s) in the aux section. But unless it's an air system issue, the tranny has to come out regardless.
    25(2)+2 Thanks this.
  6. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    91
    Feb 18, 2010
    Siler City, NC
    The back box can be dropped without pulling the whole Trans.
  7. CatPowerC15
    347
    91
    Feb 18, 2010
    Siler City, NC
    The leather is worn off the hi Lo synchronizer sliding clutch. The back box can be pulled without pulling Trans and repaired. But also like stated, check air pressures too.
  8. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Should be able to shift in neutral from low to high without the grinding if its the synchros
  9. Nicaflatbed
    Nicaflatbed Bobtail Member
    15
    4
    Mar 13, 2013
    Get it looked at soon, you may go a long time like that at best, at worst you may chew up something in the back half and it may mingle with all the gears in the tranny, and bearings and such.. Goes from being under 2k to around 4k to fix... At least I have a rebuilt tranny now...
    Hammer166 Thanks this.
