13 speed splitter issues when cold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lastgoodusername, Oct 30, 2016.
  1. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    rtlo 13 , doesn't want to split gears until it"warms up"? High/Low works fine, just the splitter. Any thoughts?
    Thanks, Johnny
  3. Couple questions.
    1. Any air hissing sound from by the shifter boot?
    2. When activating splitter, do you hear any clicks or noises from movement of switch.?
    3. Define cold? Is it San Diego and just starting truck. Or -40° Northern Canada cold?
    lastgoodusername and Bean Jr. Thank this.
  4. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    I had the same problem with the high/low selector and the air switch just needed to be rebuilt. I guess they can get gummed up from oil in the system.
  5. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    1. no hissing
    2. no clicking
    3. NC now , cold in relation to operating temp, regular outside temps, 30-40 in the morning, when this occurs.
  6. xsetra
    xsetra Road Train Member
    5,117
    6,987
    Aug 21, 2011
    Cold makes hoses and fittings shrink. You might have a press in fitting starting to go bad.
    I would check the lines where they connect to transmission.
    Good luck.
    lastgoodusername Thanks this.
  7. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    You will have to replace the 0/rings on the piston that works spliter on rear of back box, clean everything as you take it apart
  8. glockwise
    glockwise Light Load Member
    253
    225
    Apr 24, 2014
    remove the air lines at the shifter and put a few drops of mystery oil in. Not too much.
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yup.
    Just have to pull apart the spliter on the back end of trans and put new O-ring s on the slave.
  10. gearhead 1956
    gearhead 1956 Bobtail Member
    22
    Nov 2, 2016
    Your talking about two different air shifters. The main box is high and low and the back box is what your talking about. I would when its cold go under the back box and have some operate the rear splitter. Check for air leaks and you maybe able to feel the splitter trying to work and binding up.
    That's where I would start.
