If my intention is full stop or to get down to 4th gear to make a turn, should I split gears? Give me good reasons to, please?
13 speed - why splitting gears when downshifting?
Discussion in 'Questions From New Drivers' started by robs64, Aug 26, 2014.
... does this sound like a tranmission busting driver alert or am I janking the dog's chain a bit?
I trained on 10 speed and trying to learn 13.
on 13's and 18's i rarely ever split down when slowing down. split down when climbing a hill yes
Licensed to kill Thanks this. -
Exactly. If it is flat terrain RPM will jump higher but not out of the range. Why it would be a problem?
you rang?
okiedokie and Battle Born Thank this. -
Depends on speed, cornering, weight.
Tonythetruckerdude Thanks this. -
Good post....might need to add what the terrain is like during and after the turn....up-hill ( steep climb or not) , down-hill ( again steep or not )...either way slow and steady is the best way....at least IMHO.okiedokie Thanks this.
You might want the full benefit of the jake, if not don't split.
Lepton1 Thanks this. -
That is it.
To explain to a newbie. Running down a hill I might drop a half step just to let the jake be more effective or run the engine rpm under the limiter at the speed that I want to run on the hill. That is about all the effectiveness of the 13/18 in downshifting.
Running on the jake down the gears to get in low range or come to a stop by splitting is much less effective then taking whole gears. It is much more time consuming, more effort, and less actual (jake, compression) braking. Of course you may have to take one half step to get into low range just because the range shifter does not move unless you are in the lower half of the gear.Lepton1 Thanks this.
