'14 or '15 Volvo O/O's
Discussion in 'Volvo Forum' started by GITRDUN45, Apr 17, 2014.
  1. GITRDUN45
    GITRDUN45 Heavy Load Member
    712
    236
    Sep 30, 2013
    I need ideas on spec for new Volvo VNL64T670. Need spec on both reefer and van. Florida based owner but plan to do mountains , west coast all over. Need HP, Gears, Auto or Manual, Wheel Base. Any other info needed please ask. Thanks for your time and look forward to replies. Hope all is well and staying safe.
  3. BobcatVolvo
    BobcatVolvo Light Load Member
    171
    132
    Feb 23, 2014
    Western Ohio
    I will definitely be watching this thread, I'm just beginning to think about shopping for a new truck, doing very casual research now. I'm leaning towards a '15.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Lots of missing info we need. First off, what gross weights do you expect? What speed to you cruise at? Are you specing to burn op the hills at 70 mph or do you care more about mpg and saving money? Those 2 options have totally different specs. Would you consider Super Singles to save fuel? Would you consider a 6x2 with a locking dif to save fuel? (6x4 requires more power to turn, if only 1 axle is powered, you save fuel but loos some traction in snow)
    Auto or manual....wow, you just handed a serial killer a loaded gun lol. Search the forum for that answer. there are several threads on that one, although the Volvo I-shift is nice.
    platinum and flood Thank this.
  5. GITRDUN45
    712
    236
    Sep 30, 2013
    well with volvo at 20K weight, reefer trailer at 18k, full tanks on both add another 3k equals approx. 41k add me and my stuff another 1k = 42k empty loaded fuel. That leaves 38k for TL ,so I'd say I most likely be hauling close to max most the time especially hauling reefer goods. Plan to run sweet spot 68 but I'd like the power there in western states. Will have it gov. At 80 . Lol I shift is a definit. Be based in Florida so don't plan to be in heavy snow more than I have to . Will go and haul wherever money is. But I do plan on running Cali to east with produce loads. Think I covered your questions. If not please reply and I'll answer rest. Thanks
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Well to select your rear end use eaton's calculator. http://www.eaton.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf I recomend 2.64...will explain
    Personally I'd spec your truck with the overdrive ishift, BUT spec the rear so you hit 68 in direct gear (11th http://www.volvotrucks.com/SiteColl...ts/Powertrain/i-shift_spec_sheet_ATO2612D.pdf)
    This will allow a little better mpg while in 11th do to less mechanical loss in a 1:1 ratio. If you need to go 80 you will still have a whole extra gear (12th) to do it. Alternatively you could go with the direct drive ishift, but then you don't have the extra gear when you need it. Depends on how often you plan on speeding.
    Now if you want best mpg, spec the truck for 65, not 68 and slow down a bit. Since speed and power seem more important, lets try and increase mpg without sacrificing power. Since your not driving in snow much I'd highly recommend super singles. These can save you .5 mpg which is a nice chunk of change for not changing your driving habits. yes if you blow one your stuck, but how often do you blow one? Theres thread on the pros and cons if you want to read about um. I like um.
    Idealy you also can go with only one powered axle. By turning one dif and having one tag (dead axle) you reduce mechanical resistance. Also you can put a trailer tire on the tag axle since it wont be subjected to torque. trailer tires have less resistance. This will be a special item and will probably cost a few more grand but will easily pay for itself. Even if you go with 2 diffs and 2 powered axles like a normal truck, i recommend the singles.
    Xone line energy D are best for drives, and Xone line energy T are best for trailer or tag axles. Now if you planned to do flatbed and were off roading i might change my recommendation, but your gonna try to stay on the road arnt you? lol Wheelbase shouldn't be longer than it has to be for your reefer to fit behind you with the 5th slid all the way forward. It will varry based on sleeper length but no need to get longer then you need. Volvo should be able to recommend wheelbase length.
    As for hp, I'd recommend the highest horse you can get in a d13. 500 horse should be enough 98% of the time and the d16 is a lot more money and weight. last time i checked, you seemed a little heavy so going with the lighter motor should help. As for rear end, 2.64 will get you near 68 @ 1500 rpms in 12th leaving you a whole nother gear to go fast when you need to.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    may want to add air tabs, they are ugly, but cheap and increase mpg without changing driving habits. Also get yourself side skirts on the truck. A bunk heater is also a must. Yes i know you live in florida, but you may take the cold route sometimes. They burn almost no fuel and keep you as warm as you want. No need to idle. You may want to consider an apu for air cond.
  8. GITRDUN45
    712
    236
    Sep 30, 2013
    Thanks Richter. For several reasons you just got me set on D13 for sure with ishift and do. I so far not sure about my salesman cause he blurted out the specs. He said d13 Eco-torque at 455 hp ( said I don't need higher hp cause of torque and od 12 gear) 308/321 gear, wheel base 236 and gvw is 18k empty. What you think of those #'s? After rlying to your last message my weights got me worried cause 670 is 18k,trailer 14k and TK 4k and apu 400 puts me on empty at 36,400 add fuel 3k 39,400 still haven't added me and my stuff yet. What's the norm reefer load weights or where can I find that answer. What you think? I'm starting to have second thoughts and go dry van :-(
  9. GITRDUN45
    712
    236
    Sep 30, 2013
    already planned for TK Evolution APU . Also have side skirts included on trailer deal with the constant air supply to trailer tires to remain even . Sure wish I was able to run now. Shortage everywhere for reefers.
  10. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    If solo consider 630 for less weight, not sure what You save thought...
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Well IMO...more HP on a bigger engine like a d16 can reduce mpg cranking a bigger motor when you don't need it. Setting your d13 at 500 instead if 455 only alows you to use more fuel if you choose to. its the same motor, just differnt settings. the 455 is just limiting what your right foot can do. You can drive a 500 hp at 455 all day, but you will be happy to have the extra hp on the hills.
    heres the motor specs
    http://www.volvotrucks.com/SiteCollectionDocuments/VTNA_Tree/ILF/Products/D13/D13 Family.pdf
    You can get the ego tourq in 455 or 500. up to 1750 on the 445 and 1850 on the 500. Do you need 500? No! but your also talking about going 68 all the time and possibly hills. Aslong as you control your right foot they get the same mpg. but yea, if you use that extra 45 horse mpg will drop.
    Not sure on reefer weight....i know empty van is roughly 12000-15000 depending on a brand, age, spec, etc. the d13 vs the d16 will save a few poounds.. Volvos are heavy tho. Noway around that if you want a volovo
