16 Hour Rule?
Discussion in 'Trucking Industry Regulations' started by cyclerider, Apr 23, 2011.
  1. cyclerider
    cyclerider Bobtail Member
    14
    Lancaster, PA
    Guys,
    Am I wrong or not. If you leave a terminal and return to that same terminal the same day 16 hours later, isn't this legal? I understand you can do this once every eight days. I believe it is stated this way on the log book. Am I missing something? Thanks for the replies.
    cyclerider
  3. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Basically that is correct. You can work past your 14th hour but you are still limited to 11 hours drive time.
  4. Wicked Wizard
    Wicked Wizard Heavy Load Member
    985
    857
    Jul 15, 2008
    Northeast PA
    FMCSA BOOK sec $395.1 (e)(2) Short Haul operations (0) and 395.3 (2)
    This basically says if you report to the same place everyday AND return everyday, you may use the 16 hour rule once every 7 days or once after a 34 hour reset. I didn't believe it myself until I looked it up.
  5. cyclerider
    14
    Lancaster, PA
    Thanks Guys,
    I am in the US. I wonder what other rules are out there we don't know about....... Thanks again.
    cyclerider
  6. Grumppy
    3,059
    10,402
    Dec 11, 2010
    West Monroe, La
    But you still have to take 10 ours off..?? Personally, I never heard or knew about that rule either. But I would still think you have to take 10 hours off, so that would put you 2 hours later than normal comming into work the next day..?? OR are you given only 8 hours off instead???
  7. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    No Grumpy, still gotta do 10. Be careful drivers ! The scantron for scannable logs doesn't know how to read this so it will be kicked to safety for audit.
    E-logs knows how if your carrier has put the option in, some have, some have not.
    And Grumpy, you can never drive over 11 for any reason. All the 16 does is give you a way back if you were caught with excessive on duty time and you can only do it once in a given period.
    Grumppy Thanks this.
  8. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    For the love of logic will people please start reading the regulations regarding this industry before opening their mouth with incorrect information.
    Hours of service of drivers
    § 395.1Scope of rules in this part.
    (a) General.
    (1) The rules in this part apply to all motor carriers and drivers, except as provided in paragraphs (b) through (q) of this section.
    (2) The exceptions from Federal requirements contained in paragraphs (l) and (m) of this section do not preempt State laws and regulations governing the safe operation of commercial motor vehicles. (b) Adverse driving conditions.
    (1) Except as provided in paragraph (h)(2) of this section, a driver who encounters adverse driving conditions, as defined in §395.2, and cannot, because of those conditions, safely complete the run within the maximum driving time permitted by § 395.3(a) or § 395.5(a) may drive and be permitted or required to drive a commercial motor vehicle for not more than 2 additional hours in order to complete that run or to reach a place offering safety for the occupants of the commercial motor vehicle and security for the commercial motor vehicle and its cargo. However, that driver may not drive or be permitted to drive—
    (i) For more than 13 hours in the aggregate following 10 consecutive hours off duty for drivers of property-carrying commercial motor vehicles;
    (ii) After the end of the 14th hour since coming on duty following 10 consecutive hours off duty for drivers of property-carrying commercial motor vehicles;
    (iii) For more than 12 hours in the aggregate following 8 consecutive hours off duty for drivers of passenger-carrying commercial motor vehicles; or(iv) After he/she has been on duty 15 hours following 8 consecutive hours off duty for drivers of passenger-carrying commercial motor vehicles.
    (2) Emergency conditions. In case of any emergency, a driver may complete his/her run without being in violation of the provisions of the regulations in this part, if such run reasonably could have been completed absent the emergency.
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.1#Tag25
    And yes the provision that was kept secret:biggrin_25520:
    (o) Property-carrying driver. A property-carrying driver is exempt from the requirements of § 395.3(a)(2) if: (1) The driver has returned to the driver's normal work reporting location and the carrier released the driver from duty at that location for the previous five duty tours the driver has worked;(2) The driver has returned to the normal work reporting location and the carrier releases the driver from duty within 16 hours after coming on duty following 10 consecutive hours off duty; and(3) The driver has not taken this exemption within the previous 6 consecutive days, except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by § 395.3(c).
    Jeez crack a book(or a web page ) every once in a while:biggrin_25510:
    NDBADLANDS Thanks this.
  9. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Never mind Tazz, ........
    rockee Thanks this.
  10. double_r
    double_r Heavy Load Member
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    Section E: http://www.fmcsa.dot.gov/rules-regulations/truck/driver/hos/hos-faqs.asp
    The 16 hour exemption for LOCAL DRIVERS was never a secert. Some companies will even route ONE sixteen hour day into a driver's route.
    It allows us to drive PAST the 14th hour, but not exceed 11 hours of driving.
    chalupa Thanks this.
