16 prostar electrical fault
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BigWheels2012, Jun 6, 2020.
  1. BigWheels2012
    BigWheels2012 Bobtail Member
    18
    5
    Jun 6, 2020
    My son left the battery charger on the truck at 40amps overnight. Its a 16 prostar with the cummins and automatic. Immediately after this, the def guage will not read properly, the dash says electrical fault, the truck starts but when you turn it off it continues to run for 10-15 seconds with the key out of the ignition before turning off. I checked all fuses and disconnected the batteries but not luck. Any ideas?
  3. Magicautocenter
    Magicautocenter Bobtail Member
    23
    9
    May 21, 2017
  • Draft saved Draft deleted
