18 Pete 579 w/x15, Lost power to my pigtail
Discussion in 'Peterbilt Forum' started by REEFERman450, Aug 12, 2018.
  1. REEFERman450
    REEFERman450 Light Load Member
    189
    63
    May 3, 2016
    Lost power to my pigtail connector at the Tractor.
    Test lighted all fuses under hood, left side kick panel in cab and side box and all are OK.
    Crawled under truck and all connectors are good.. Nothing grounded out or bare wires.
    I've changed out all 30 Amp Fuze and nothing.
    I've changed out all relays and nothing.
    Any help is appreciated.
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Sounds crazy but..... did you try a different pig tail.
  4. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Is every pin dead? Is anything working?
  5. REEFERman450
    189
    63
    May 3, 2016
    Yes
  6. REEFERman450
    189
    63
    May 3, 2016
    9/3 pins hot... All others mo
  7. pushbroom
    pushbroom Road Train Member
    1,779
    7,317
    Sep 1, 2012
    Last 6 of s/n
    Exactly what pins/ lights aren't working?
    Hegemeister Thanks this.
  8. REEFERman450
    189
    63
    May 3, 2016
    Last 6 of VIN are 498329
    With lights off only Center pin lights.
    With light to marker position... Center pin and 1 o'clock pin light up.
    With light to on (marker plus headlights), Center pin and 1 o'clock pin light up.
    All other pins are dead in all 3 positions.
  9. pushbroom
    1,779
    7,317
    Sep 1, 2012
    So no taillights, turn signals or stop lights?
  10. REEFERman450
    189
    63
    May 3, 2016
    I've got all lights now but had to run all wires from number 6 post to the number 2 post to get lights operational...
    So what ever my issue is, it's connected to the number 6 pin on the Tractors pig tail connector.
    Could the cab switch have went bad?
  11. pushbroom
    1,779
    7,317
    Sep 1, 2012
    Again, what lights are you trying to get to work? It sounds like your aux and clearance lights work. Do your signal lights work? Do your taillights work? Stop lights? If you can tell me exactly what circuit does not work I can help you.
    Pin numbers mean nothing as I have no idea if you are on the plug or jack.
    spsauerland Thanks this.
