18 spd vs 15spd/9LL
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by greaseburner, Mar 11, 2018.
  1. greaseburner
    greaseburner Light Load Member
    155
    45
    Got a dump truck with a 3406E 550hp that wore out an 18 spd. Mechanic says 18spd isn't as strong as an 15 spd/9LL. Usually he's not one to spin a yarn, so just double checking.
    Thank you
    skellr and 1976bigred Thank this.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Need the whole trans model #'s to make that comparison.
    SAR, greaseburner, Oxbow and 3 others Thank this.
  4. greaseburner
    155
    45
    so there's no rule of thumb rule.....
  5. AModelCat
    155,465
    18 speed. Only way to go. More versatile. I believe the typical 18 has a lower starting gear than the 15's. The 18 has 18 useable ratios vs 12 for the 15 speed. 15 can't be split so its basically a 10 speed when being driven on the highway. A modern 18 speed can handle like 2,050 ft-lbs. I think most 15's are rated less than that. I know my old 15615 is only good for like 1,500 or 1,550.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,422
    6,446
    Aug 26, 2014
    The first two numbers are how many hundred foot pounds of torque the transmission is rated for. If you reduce that your backing up.
    If a lesser rated transmission is better rated for you application I can not answer. I know that sounds stupid. As in the case of a drilling truck with a splitter box, kind of like a bownie, with two output shafts. One for the truck and one for the drill. It normally ran in third gear drilling. When it was uprated to a different model trans it would not stand the high sustained torque in third gear.
    Intothesunset, greaseburner and Oxbow Thank this.
  7. easytopleez33
    easytopleez33 Light Load Member
    251
    324
    Jan 6, 2015
    RTLO18918 Will handle all a 550 cat can give it.
    If that's what you were running
    Intothesunset, MartinFromBC and Oxbow Thank this.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Ratings aside, I've seen some 15 speeds that live a long long time behind some hot hot 3408 cats and 600 KTAs.
    There a very strong trans that take a lot of abuse.
    Having said that a good rtlo 18 would be every bit capable.
    Yours was prob just that, wore out.
  9. greaseburner
    155
    45
    Bingo, bingo......
    I figured this one was fine, but it's shot and my mechanic was saying that they aren't as heavy he thought, so thus the reason for my question.
    Thanks
  10. greaseburner
    155
    45
    I understand that, as some transmissions are built specific for a certain type of jobs, but that doesn't mean everything in the transmission is as heavy......
  11. C15Mike
    C15Mike Light Load Member
    54
    27
    Sep 15, 2016
    The 18918b will handle anything you can throw at it as previously mentioned. I just put on a stage1 turbo and a Mr. Haney tune in my C-15 and soon will be putting this trans in my truck. My truck is putting down a lot more power than a stock 550hp 2050ft/lb torque motor and I've talked to many knowledgeable people and this is the trans along with a 2050 eaton clutch they suggest
