18 speed Auto Shift, anything to be aware of?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr. Cob, Nov 27, 2017.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    I found a truck I may be interested in, it has a 3 pedal, 18 speed, Auto Shift, transmission in it, anything I should be aware of, possible problems, things to look for? Thanks for any information you can share.
    Dave
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    You can throw a stick in it for a few bucks. Most likely.
  4. Brandt
    Brandt Road Train Member
    4,604
    6,325
    Sep 17, 2012
    If it's Eaton or sounds like it and older auto shift. They had trouble when they first came out. The computers could mess up and not shift gears.
    The new modern Auto shift transmission are way better. The engine and transmission work together. The can talk to each other and that give you a much better setup. The transmission can tell the engine to turn on engine brakes when shifting in low gears. So the transmission doesn't miss a gear. The new DT12 transmission has GPS locations of the big hills. So it won't keep shifting gear when climbing a hill.
  5. Mr. Cob
    Howdy All,
    The transmission is Gen2, Eaton-Fuller, Auto Shift. I have the 10 speed version in my Freightliner and it works very well. I am asking questions about the 18 speed version of this transmission as I had no idea they made an 18 speed version. I have driven the newer two pedal transmissions and didn't like them, I like having the clutch pedal makes it much easier to creep up on the pin or get started on slippery stuff.
    Dave
  6. Roger Marsh
    Roger Marsh Bobtail Member
  7. Roger Marsh
  8. Roger Marsh
    I have a 18 speed auto shift Eaton fuller it want down shift stuck in high gear.It will go in reverse also if you turn the key without the clutch it will try to start.If you don't have the clutch in when you try to start the transmission will try to turn
  9. Mr. Cob
    Howdy All,
    I guess I should update this thread. I bought the truck have driven it 40,000 miles in the last three years love the 18 speed Auto-Shift it has worked perfectly the truck was never in fleet service I am the third owner and have been in contact with the widow of the man who bought the truck when new they were team drivers.
    Dave
    Brandt and Flint1 Thank this.
