18 speed temp hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by High Water, Mar 3, 2021.
  1. High Water
    High Water Bobtail Member
    5
    Mar 3, 2021
    New England
    2005 W900L
    Had a 10 speed in it. Put in an RTLO 18918.
    Temp is always very hot. 300 +
    Should I put in the temp sensor from the 10 speed to make sure the resistance is correct ?
  3. AModelCat
    160,478
    I would start with that if it'll fit without interfering.
    Can shoot the housing with an IR temperature gun too to confirm the temperature.
    300 is HOT!!!! If its running at that temperature it'll be burnt up in short order. Anything above 250 you're cooking the oil.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    18 spd usually requires a cooler. Did the 10 speed have one?
  5. High Water
    5
    Mar 3, 2021
    New England
    The 18 speed came with a water style cooler.
    I stopped at Kenly and put my hand on it when it was showing 300 degrees... It was hot but not 300.
    That’s why I’m thinking the sending unit should match the truck gauge
    uncleal13 Thanks this.
  6. High Water
    5
    Mar 3, 2021
    New England
    I think I’ll take my IR gun with me on the next trip.
    Good idea,,,,
  7. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Does it always read 300? Does it start out at 300 or slowly climb up? Does it fluctuate during the day?
  8. SmallPackage
    5,531
    17,613
    Dec 20, 2019
    Marion Texas
    Where does the gauge needle park when key is off?
    On the Peterbilt gauges they normally park around the 150 degree mark when key is off. Turn key on and it will move needle to read actual temp if above 100. That is one way of knowing if the gauge or sender is still working correctly.
    I’m just not sure if the KW’s do the same thing.
    I’m like everyone else and agree the sender in the trans does not match the gauge in the dash. Easy fix.
  9. High Water
    5
    Mar 3, 2021
    New England
    After an hour or two at the truck stop it's down below 140..
    Kenworth's seem be ohm sensitive on most of gauges
  10. High Water
    5
    Mar 3, 2021
    New England
    Going to call Kenworth tomorrow and get a new sending unit that was in the original 10 speed....
