1972 Kenworth W900A turn signal issue
Discussion in 'Kenworth Forum' started by Seabee71, Sep 4, 2024.
  1. Seabee71
    Seabee71 Bobtail Member
    9
    10
    Dec 16, 2022
    I need some assistance. I have a 1972 W900A. Bought it a month ago. Driving it home the right turn signal did not work front or rear. The left side worked, front and rear. The brights worked as well. The rear are LED lights the fronts are incandescent. Started with replacing the turn siginal switch, because you could hear the flasher clicking in the dash. Didn’t work. The rears light up solid with no flash, fronts do nothing. Replaced the flasher. Rears still light solid no flash, no clicking from the flasher unit. The x terminal of the flasher unit has power with key on. I’m stumped at this point, any help would be greatly appreciated.
    OLDSKOOLERnWV Thanks this.
  3. SmallPackage
    5,568
    17,717
    Dec 20, 2019
    Marion Texas
    Doe’s it have the Signal-Stat 902 on the column and head light dimmer on floor like oe or did someone monkey in a new style turn/dimmer switch on column?
    Seabee71 and Oxbow Thank this.
  4. Seabee71
    9
    10
    Dec 16, 2022
    Yes, signal stay on the column and dimmer on the floor. I did replace the signal stat switch with a new one (probably Chinese made), but I did take the back off and insure both switches were wired identical.
  5. SmallPackage
    5,568
    17,717
    Dec 20, 2019
    Marion Texas
    Those switches ground to steering column through their body mount and strap. They require a 3 prong flasher. The center prong is the “pilot” to power and flash the light bulb in the switch. One for 12v constant battery power. And the other is for the flash signal to switch. If it works on one side then flasher is good. It doesn’t know what side is what. The switch itself is what determines direction the flasher signal goes. If that stuff is good i’d check to make sure the lolly pop light on front fender has good ground. The body itself has to ground through its mounting stud. Fiberglass hoods make this diffecult. You may have to run a dedicated ground wire along the light harness from the 1/2” threaded light mount to the frame or radiator support.
    MACK E-6, Oxbow and Seabee71 Thank this.
  6. SmallPackage
    5,568
    17,717
    Dec 20, 2019
    Marion Texas
    If were the wires going to the flasher are individual and have no harness plug any more you can use a replacement plug or a salvage plug from a high/low beam headlight socket. They are the same exact spread.
    Oxbow, beastr123 and Seabee71 Thank this.
  7. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    make sure your front bulbs are good. the LEDS won't pull enough juice to make the flasher work.
  8. 201
    201 Road Train Member
    12,457
    25,472
    Apr 16, 2014
    high plains colorado
    I'd have to think on a 1972 anything, the turn signals will be the least of your worries.
  9. Seabee71
    9
    10
    Dec 16, 2022
    MACK E-6, SmallPackage, Oxbow and 2 others Thank this.
  10. Seabee71
    9
    10
    Dec 16, 2022
    It’s in really good shape for a ‘72
  11. OLDSKOOLERnWV
    18,595
    280,796
    So the right side turn signals don’t flash but the left side does? And the right rear light gets bright (but no flash) with flasher in right turn position but right front does nothing?
    Take a test light and check for power on the contact of the right front signal, have to remove the bulb of course. Make sure you have a good ground and don’t short the test light out bumping the metal bulb holder. It may be as simple as a bad round or broken wire. But need to confirm you have no power to right front light first….
    beastr123, Seabee71 and Oxbow Thank this.
