1985 detroit 6v92 motor problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Farm678, Sep 12, 2017.
  1. Farm678
    Farm678 Bobtail Member
    I didn't look at any drains to the oil pan, I thought there should be no oil in the air box but I will check to see. Also could there be a bad valve in the head of the engine dumping oil back into the piston and pushing the oil through the open sleeves
  3. SheepDog
    SheepDog Road Train Member
    3,481
    2,084
    Nov 30, 2008
    Sand Lake, MI
    My Cummings Big Cam III 400 smokes,, thought it was normal...lol
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Oil in the air box can have a few different causes but most of them involve disassembly to verify & repair. Like Box Car said wrist pin seals, worn rings can all cause the issue. You could just take apart the side thats pumping the oil. If the heads are ok you could put some liner kits in it. If you end up reusing the pistons be sure to disassemble them & replace the seal ring between the skirt & dome.
    When you replaced the blower did you go over the governor settings to be sure the racks are balanced?
    BoxCarKidd and SheepDog Thank this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    At one time ( 1978-81? ) The air box drains were connected to the oil pan. It did not work out and a campaign was sent out to remove and let em slobber on the ground. That and the correct oil can make a big difference.
    Some oil in the air box is normal and why they have air box drains to relieve it. That is a 2 cycle engine like a chainsaw, made to run not idle.
    cnsper Thanks this.
  6. AModelCat
    161,680
    So that's where the term "Green Leaker" comes from I guess.
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    The only reason a detroit dosent leak oil is because its out of oil.
    Grubby Thanks this.
