1988 turbo issues
Discussion in 'Western Star Forum' started by n4ane, Nov 19, 2020.
  1. n4ane
    n4ane Light Load Member
    132
    59
    Aug 28, 2020
    Ok so the problem child has struck again. Trubo us starting to go out so I need to replace I can't read the engine serial number. Motor isn't original to truck and has been changed so I am lost for a part number. I just need oe replacement not really looking to upgrade since I dont have the money. Also part number on the turbo doesn't match anything that was supposed to be there
    jamespmack and OLDSKOOLERnWV Thank this.
  3. AModelCat
    157,828
    It'd be helpful to know what this turbo is going on.
    MACK E-6, Shawn2130, Dino soar and 3 others Thank this.
  4. n4ane
    132
    59
    Aug 28, 2020
    You have a good point motor is supposed to be a big cam 400
  5. MACK E-6
    48,581
    223,547
    How about some pictures?
  6. n4ane
    132
    59
    Aug 28, 2020
  7. n4ane
    132
    59
    Aug 28, 2020
  8. n4ane
    132
    59
    Aug 28, 2020
    I will also have to take the manifold off and replace the gaskets because cylinder 6 has decided to start leaking
    jamespmack Thanks this.
  9. OLDSKOOLERnWV
    18,211
    274,177
    Cummins.
    Look on top of the fuel pump, there is a tag with the fuel code on it. This will let you know what it’s calibrated for ( horsepower ).
    Call your local shop that builds pumps and give them the numbers, they should be able to tell you what the pump is built for.
    If they can’t help you, post a pic of the tag and I will make a call.....
  10. OLDSKOOLERnWV
    18,211
    274,177
    Tag will look like this....
    n4ane and jamespmack Thank this.
