1990 379 low air volume from vents.
Discussion in 'Peterbilt Forum' started by Tennyshoe, May 17, 2023.
  1. Tennyshoe
    Tennyshoe Bobtail Member
    Fan motor works on all speeds. Blend doors are directing air flow. Just very low volume of air from any location, defrost/dash/ or floor. Any suggestions?
  3. Big Road Skateboard
    3,630
    16,705
    May 2, 2021
    You're either losing air somewhere, blower motor ain't working good, blend doors not sealing, or the thing could be completely covered in dirt.
    How many times has the housing been fixed?
    Bean Jr. Thanks this.
  4. Tennyshoe
    Truck new to me don't have history on any a/c, heater repair. However looks like a new heater core has been installed recently, cleaned all parts while I had it down.
  5. Big Road Skateboard
    3,630
    16,705
    May 2, 2021
    Do you feel any air loss around the box? And do yoy feel air from multiple vents? Such as floor, defrost, vent
  6. bad-luck
    bad-luck Road Train Member
    2,922
    5,145
    Nov 16, 2013
    Baltimore, Maryland
    Have youbreplaced the cabin air filter?
  7. Goodysnap
    Goodysnap Road Train Member
    3,348
    7,939
    Jul 12, 2017
    Pull the Heater core and evaporator. Most likely blocked by fine dirt, debris.
    Clean or replace.
    The filter is just a rock catcher.
  8. Diesel Dave
    6,595
    10,794
    Jan 20, 2010
    Hesperia, Ca.
    My former 1994 379 didn’t flow enough air in high in my opinion, even after I blew air through the evaporator. The sleeper would freeze your arse off. My replacement truck which is a 2014 Pete, on the hottest day, no need to go higher than 2 on the dial out of 4.
    On my 379(former), I ran a clip on oscillating fan between the seats and would circulate the air better.
    Tennyshoe Thanks this.
  9. Coolbreezin
    Coolbreezin Medium Load Member
    331
    300
    Jun 11, 2016
    Florida
    '91 379 here. I feel your pain. I removed the glove box then a/c fan. Cleaned the fan blades well (bird cage?) and flushed out the heater core as best I could with some kind of top secret OMG Heater Core Cleaner Outer foam and standard garden hose. Lotta crap was flushed out but didnt really help much. Fan needed a good cleaning though. I do have some cracks and leaks in my dash too.
  10. JB7
    JB7 Medium Load Member
    340
    410
    Dec 13, 2022
    Truck is 33 years old. Check all the ductwork. It may be cracked, disconnected, not sealing at the joints/connections. Blow air through the ducts. Maybe a critter made a nest though most of the time that ends up in the fresh air intake and blower motor.
    Oxbow, Tennyshoe and Bean Jr. Thank this.
  • Draft saved Draft deleted
