1995, 9800 air leak on switches
Discussion in 'International Forum' started by silveraden, Sep 6, 2014.
  1. silveraden
    silveraden Bobtail Member
    10
    Aug 29, 2014
    We purchased a second-hand International 9800 model 1995 and we are on the process of restoration. I never opened this thing before and I don't know if this is repairable. Any help is highly appreciated. Thank you
  3. Heavyd
    Heavyd Road Train Member
    7,629
    6,033
    Feb 4, 2009
    That is a standard MV3 valve, or dash park brake valve. There are orings in side that dry out/rot. You would replace that whole valve.
  4. silveraden
    10
    Aug 29, 2014
    Can I replace just the orings? I'm in Philippines and spare parts for these American trucks are very limited. And I guess this whole valve is too expensive.. Thanks
  5. baha
    baha Road Train Member
    4,137
    2,834
    Jul 25, 2013
    ga
    Be very care/full taking the valve apart over a pan, springs and parts will be everywhere after pulling face off front of valve, o/ rings are smaller/thiner than ones found at hardware store?
  6. silveraden
    10
    Aug 29, 2014
    I will try to dismantle this whole thing tomorrow and will check if I can find similar Oring from auto supply stores here. I found a replacement valve and it costs $130 including shipping from Ebay.
  7. Pahrump
    Pahrump Medium Load Member
    best to replace both valves..order on the net you can get next day shipping world wide,, these valves are not rebuildable
  8. silveraden
    10
    Aug 29, 2014
    This truck has been out of operation for more than 3 months but we always turn the engine ON almost everyday to warm-up everything. I'll see if what I can do tomorrow. Thanks
  9. EHB
    EHB Medium Load Member
    491
    206
    Apr 26, 2011
    Newfoundland
    Some units you can rebuild
  10. Heavyd
    7,629
    6,033
    Feb 4, 2009
    Sometimes you can just wiggle the buttons up and down to help slow down the leaks. Yes, you can install a seal/oring kit. I'm not a big believer in that. The valving is just plastic and also several years old. It will be worn. I recommend to replace it and be done with it.
