im working on getting an old 1995 FLD back on road. Currently I’m stumped on the low air warning system (it’s not working). The original buzzer and light were located in the dash info bar. But that device was damaged and has been removed.
I’ve located the low air sensors, there are two of them behind the steering column. I can verify this because they both have red stripes which indicate the LAW system. But they’re so deep in there I can’t reach them. I’d have to dismantle the steering column to reach these things.
Even if I do reach them, I don’t know how the circuit works. Do these sensors work together to put out one signal? Would it be a 12v or ground signal? Does the signal come on at 60psi?
I’d love to find the wire still existing in the dash, hook it up to a light and be done. it probably still in there. But there’s nothing but 1000 yellow wires in there plus I don’t know if I’m looking for a ground or 12v signal or if it comes on or turns off at the 60psi.
Any help on this would be great.
1995 Freightliner FLD Low Air Warning
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trugo, Dec 20, 2018.
Those should be normally closed switches it takes 60psi to open them and kill the circuit. They are wired in parallel so that either sensor will set the alarm. I’m not for sure if they are controlling the power or ground side of the circuit. But you should be able to check with a test light if you can get the kickpanel / carpet pulled back on the left side of the column.
That’s all I got, hope it helps.Trugo and BoxCarKidd Thank this. -
I always thought they ran off the Parking brake . Air switch screwed into it
Trugo Thanks this. -
That has been a while and the Workingtoparty,s post just came in. One switch is for the primary and the other for the secondary air tanks. They are independent and either should sent off the alarm.
If the dash unit is damaged you can buy an old school buzzer and wire it into one or both of those switches. I have never heard of the system being tested on both tanks independently. You may want to install and wire a light to it also although I do not thank it is required. I prefer to maintain as original but sometimes we have to run and make ends meet.
This system is out of service criteria if not functioning and has been battled here before. The light is for the deaf driver and the buzzard is for the blind driver.x1Heavy, Working2party, Trugo and 1 other person Thank this. -
Rideandrepair Thanks this. -
I went out and tore out the carpet behind the steering column. By this point I could see 4 air switches. 2 of them are looped together with one going to ground and the the other going up to dash. I was able to trace that one behind the speedometer. This wire does work using a test light. I’m getting a ground signal above 60psi. Which is good news.
But this presents a challenge for my basic wiring skill. I need a ground below 60 psi to activate a light and buzzer.
How to wire such a situation? -
Use that to operate a 5 terminal relay or install normally closed switches.
AModelCat Thanks this. -
this 5 pin relay works. the light and buzzer work good.
