my truck has been completely gone through. Motor tranny and rear ends all have less than 200,00. My problem is a clutch noise at an idle. It goes away as soon as I press the clutch and doesn't happen all the time.. The shop I use is saying the crank is moving and causing the issue. I do not buy this because if it was the crank I feel that the rear main seal would be leaking. I think something is wrong with the flywheel or the clutch because none of this started until after they resurfaced the flywheel and put in new clutch. Issue is not in tranny either it made the noise with the new one so we put my old one back in and still same noise
1998 international 9400 n14 red top
Discussion in 'International Forum' started by sgtriverrat, Oct 22, 2017.
