2.5 gals of DEF then empty?
Discussion in 'Questions From New Drivers' started by I3IGBIRD26, Jan 24, 2022.
  1. I3IGBIRD26
    I3IGBIRD26 Bobtail Member
    36
    7
    Jun 25, 2021
    Similar but not exact on here-
    Bought a 2014 t680 w/ 554k miles. DEF indicated 3/4 when I got in. Took me longer than I’m going to admit to realize it wasn’t moving. MIL light came on but no engine light. DEF tank never takes more than 2 gals. Gauge goes to full than drops to 3/4 quickly. Then weird things start happening if I don’t fill up with another 2gals. I’ve just started carrying an extra 2.5 gals with me. Sometimes the “STOP” light flashes for a mile then goes out. As soon as I put 2gals back in (and it shoots back out) everything goes back to normal. It’s getting expensive and time consuming. I’m new and on my own but 2gals to fill tank??? Never takes more.
  3. Siinman
    Siinman Road Train Member
    5,455
    14,025
    Mar 5, 2017
    Kansas City, MO.
    Should. be around 15 gallons. Something wrong
    86scotty and tscottme Thank this.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    You left out a important part How Far can you travel on those two gallons .. part of me thinks you have a partial delete of def system.
  5. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Could be a DEF level sensor going bad.. or somebody was "tinkering" and botched it.
    WesternPlains Thanks this.
  6. I3IGBIRD26
    36
    7
    Jun 25, 2021
    About 400 miles
  7. Magoo1968
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    That’s normal consumption so most likely level sensor
    Frank Speak Thanks this.
  8. WesternPlains
    6,353
    56,615
    Sep 1, 2017
    Rapid City, SD
    System is goofed up. Get it fixed.
    You do realize. If you run out of DEF. You’ll burn your truck down. Literally.
  9. Ffx95
    Ffx95 Road Train Member
    1,369
    2,632
    May 18, 2017
    I’m guessing the def quality sensor. If it is don’t ignore it and get it checked cause eventually it’ll leave you on the side of the road in limp mode. Not sure if paccar dealerships are back to stock with those sensors if they still aren’t they’ll probably have the truck computer bypass it. Your def gauge won’t work afterwards you gotta make sure it’s always full.
  10. Long FLD
    Long FLD Road Train Member
    12,534
    52,101
    Mar 4, 2015
    Lol. What?
    200 miles per gallon sounds about right. Since you have lights that come and go you should get in and get the def sensor checked. Your truck will derate if the computer thinks your def tank is empty.
    Magoo1968 Thanks this.
  11. Mike250rs
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Depending on the model.. I had a truck down for 3 weeks waiting on one.
    After many phone calls with the sales guy and shop, they were given 3 choices:
    1. Fix it
    2. Provide a free rental
    3. Make the truck & driver payments
    Truck was on the road 2 days later.
  12. Long FLD
    12,534
    52,101
    Mar 4, 2015
    If they don’t have sensors available right now there is a software workaround. It’s been available since September. Just takes some paperwork from the dealer.
