2 axle vs 3 axle truck
Discussion in 'Questions From New Drivers' started by TheRedskinsWay, Sep 17, 2011.
  1. TheRedskinsWay
    TheRedskinsWay Light Load Member
    174
    36
    Mar 11, 2011
    Columbia SC
    for about 4 weeks i have been driving and alley docking with a 2 axle truck. now that truck has a transmission problem so now i have to move to a 3 axle truck. i didnt really have a big problem docking with the 2 axle ill get it in 8/10 tries but now im struggling to dock this truck with the 3 axle im lucky to get it in 3-4/10 tries. So is there a big difference backing between the two?
  3. 7122894003481
    7122894003481 Bobtail Member
    1,996
    Sep 6, 2011
    Slight difference.
    The bigger difference comes when you go from a daycab to a tandem axle sleeper, or a stretch frame.
    TheRedskinsWay Thanks this.
  4. johnday
    johnday Road Train Member
    Are you asking about a tridem trailer, opposed to a tandem?
    Or the tractor going from single drive to two drives?
  5. TheRedskinsWay
    174
    36
    Mar 11, 2011
    Columbia SC
    Single drive to two drives.
  6. johnday
    Gotcha. If the wheelbase is the same, there won't be much difference. There's a bit more to it though. Each brand of truck has a different wheelcut, as well as each model.
    I'm assumming it's the same make/model, so usually the wheelbase will be a bit longer, and it will take the tractor a little longer to turn, especially in reverse. You'll get used to it.
    The truck I usually drive is a 4900SA day cab, turns great, forward or reverse. Then I get the other truck, T800 with sleeper, world of difference there. But after an hour or so, all is good.
    I think you've already answered your own question.:biggrin_25525:
  7. nitrogen
    nitrogen Medium Load Member
    569
    248
    Oct 3, 2010
    Calgary Alberta
    the wheel nut just needs slight recalibration :) wait til they give you a 53 foot trailer and teeny tiny yard to dock it in, or a set of "B-trains"
  8. johnday
    I caught that!!!:biggrin_2559:
