2 check engine lights on and my DEF fuel light on but I just filled DEF tank
Discussion in 'Freightliner Forum' started by Andy at ABC TOWING, Aug 4, 2016.
  1. Andy at ABC TOWING
    Andy at ABC TOWING Bobtail Member
    I have 2 check engine lights on and my DEF fuel light on but I just filled my DEF tank up..what does this mean
    One light is a engine light that says check in the middle of it and the other is just a engine light
    The DEF light is on as well but I have a full DEF tank
  3. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    What year and what engine?
  4. WildTiger1990
    WildTiger1990 Heavy Load Member
    839
    1,418
    Apr 21, 2015
    Have you ever used truck regen while parked ?
  5. Brandt
    Brandt Road Train Member
    4,423
    5,964
    Sep 17, 2012
    If the low DEF light is on that probably is turning on the check engine like. The computer probably is being told your low on DEF even with full DEF tank
  6. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    Check the wiring harness around the def tank. I've had problem with them fraying and breaking off from the sensors.
    danny23tx Thanks this.
  7. dunchues
    dunchues Medium Load Member
    544
    955
    Mar 23, 2012
    new brunswick
    Happened to me last week. Let the def level get down to 10%, then when I filled it up it lit up the warning lights like yours. Had to go to dealer to reset the codes too.
  8. 1fixitman
    1fixitman Light Load Member
    68
    14
    Aug 16, 2016
    Rarely do people report back and say what the issue was and what they did to solve the problem. Did you find out what was wrong?
    driverdriver Thanks this.
  9. dunchues
    544
    955
    Mar 23, 2012
    new brunswick
    Seems if you let the def level get too low it sometimes triggers a warning code which doesn't clear itself when the tanks refilled, needs to be wiped by dealers laptop.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    On a new Detroit most codes will clear themselves after three successful engine starts after the condition has been fixed.
    The check engine lights should go out. But I find that the DEF yellow warning light still flashes. It acts as a tattle-tale if you completely run it out of DEF, I have the software to reset it myself.
    1fixitman Thanks this.
  11. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    I ran the 2013 to the yellow and it derated almost immediately, to 55 mph.
    I filled it up on the road and it held 20 gallons, the tank holds 23, so that one probably wouldn't get to a point where there was no def.
    We are supposed to fill at the shop, it's cheaper by far, but they don't always do it, and they aren't always there when I get there so I could do it there myself.
