Okay so a couple months back my trusted old Gamin freaked out. Started having Chinese characters all over the screen and the routes were complete nonsense. Well I had over 400 bucks in Loves points so I decided to buy the new 7 inch RM. I updated my Garmin when I got home and its fixed now. I figured I would just keep them both and see which one did better routes.
Since this comparison is between two different and year models this won't be a feature comparison. Everyone puts different values on different features anyway. We are going to focus on routes. But let me start by saying that I will never again purchase a 7 inch GPS, it just takes up to much real estate. I like to mount my GPS to the top of the overhead compartment, the big empty space that makes up the floor for the center compartment for those driving a Cascadia. I always buy those Bracketon mounts from Loves. However, I found the 7 inch bracket just simply would not stabilize the RM from this position, it vibrated like crazy. I ended up mounting it in the space where some Cascadias have their CB's.
Anyway on to the comparison. I found them both to be much the same for the majority of the time but with some huge exceptions. If you run out of the West the RM is way better. For instance, Denver to Dallas. Garmin wants you to run I-70 all the way to 35, which does work but is way longer. The RM routes what I consider the proper way, U.S 287. Cheyenne to Houston, Garmin wants you to run I-80 to 35. Basically, it will always pick the long way from anywhere out West, north of I-10. Anything from the Midwest or East the were both the same for the most part.
Another issue is the Hazmat routing, Garmin wants you to run I-35E through Dallas when that is clearly a non Haz route, RM routes you correctly. RM never let me down in this regard.
So, which one will get you to the front door the best? Well, they both will actually but the RM will take you on a really screwed up way. Say you could exit the freeway and make one tun and be there, call it a total of 2 miles from the exit. Garmin will do that route, the RM has a tendency to route you an exit or two before and then do a bunch more turns. So I found the Garmin to be better for city driving, or final destination driving.
There is one feature that cannot be overlooked. The RM needs wifi to do traffic and the Garmin does not. This is a huge difference and I simply cannot believe RM lets Garmin get away with such a critical advantage. The Garmin traffic, and Ive been running mine 3 years now, is usually accurate and is a great help in planning. I will not hotspot my phone and waste precious data so I never even used it on the RM. Again, its almost inexcusable that the RM doesn't do the same thing.
So whats my final verdict, which one do I pick? Well, I'm a Garmin fan boy but honestly the RM is just a lot better for routing. I mainly use my GPS to give me miles to go, how much longer I have to drive to be in range, should I stop here etc. Routes really aren't all that important in terms of turn by turn. I generally know where I'm going. The RM simply beats the Garmin in finding the shortest route my consistently. I would recommend the RM hands down but incredibly they can't even come close to competing on traffic. So when my Garmin finally dies and then the RM goes, hopefully a long time from now I will buy another RM and hopefully by then they will have a traffic feature that doesn't use wi-fi.
20,000 miles RM vs Garmin side by side review.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by ethos, Dec 25, 2015.
Page 1 of 8
pensive, Blackshack46, Buckeye Don and 2 others Thank this.
Also, let me put this disclaimer here. If your one of those old school "I don't use GPS and you're stupid for using one and by God all I need is a paper map" kind of guy. That's awesome and we should all be so lucky to be you. But I don't need to hear about it. So please, simply do not post. In fact why would you even click on this thread?
2duisperyear, scythe08, austinmike and 7 others Thank this. -
I clicked on this thread because I thought it was about motorcycles
2duisperyear, austinmike, Blackshack46 and 3 others Thank this. -
poppapump1332, Call_Me_The_Breeze, austinmike and 5 others Thank this.
Question, do they both show your speed versus speed limit and if the do are they both fairly close?
I think the Pittsburgh, PA area would give both of them fits, and forget NYC. -
Call_Me_The_Breeze, Mudguppy and Canned Spam Thank this.
25(2)+2 Thanks this.
I wouldn't ride without oneaustinmike Thanks this. -
Friend, thank you for posting this. I'm going to be in the market for another GPS soon and was having trouble making up my mind which one I wanted. Well written, vital information that most have enormous difficulty finding in one place.
(Where's my helmet...?)Canned Spam and ethos Thank this. -
Thanks for your review.
Yes, Garmin is way out front on traffic and weather functions over the RM units. On Garmin units traffic and weather are via radio signal and have some limited range outside of metropolitan areas. You can add extended subscriptions to the Garmin. Not something I have bothered to explore.
I have been using the new 770 model for about 6 months.
I find that it has better routing options over the older 560 model it replaced. The 7 inch screen did concern me at first. It's a big unit. However after a few weeks, I found that the larger screen was easier to read in most conditions.
I agree that for last mile directions, the Garmin products are far superior to getting into locations than the RM units.
Neither unit is perfect, some times they are off. The Garmin seems to be less often.
On an over all, I tend to like the way Garmin wants things input to the unit. Has a bit more of a logical sequence over the RM units. Then I am used to using RPN and UNIX.
Truth is, it was first generation (500 and700) RM units I was using, so they may have changed this in that time.
On both units, function buttons can be placed in different screens. I find the Garmin offers more options to customize these choices. Giving quick access to these functions from a number of screens or locations
Tools on the Garmin units work for me. The IFTA and trip reports are easy to use. Makes paper work a snap.
Planning and programming multi stop routes, the Garmin is the better choice I believe. One feature that stands out here is the route shaping ( this may only be on the 770) it lets you really customize routing. The Garmin also has better on the fly routing changes. Tap and go.
The GPS is a tool to aid in planning and routing. Tracking progress and meeting schedules.
Page 1 of 8
