20 c. Truck doesn’t start. When the temperature from -10 till 0 degrees it runs good but engine star
Discussion in 'Volvo Forum' started by VOVAN 29, Feb 12, 2020.
  1. VOVAN 29
    VOVAN 29 Bobtail Member
    4
    VOLVO VNL 780 2015.
    -20 degrees Celsius. Truck doesn’t start. When the temperature from -10 till 0 degrees it runs good but engine starts with the delay when I turn ignition on .
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    -20 C that engine does not shut off. You would have a dead truck on your hands. Engine running = life in that kind of cold. No wonder.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    When you turn on the key, wait for all the lights to go out on the dash. Other than low air. One may be an indicator for glow plugs if your truck has them. When it’s really cold, you may have to plug in a block heater.
  5. Paul Chamberlin
    Paul Chamberlin Bobtail Member
    40
    20
    Aug 6, 2018
    Highway
    Under 0deg let it run or plug it in. If not you will need a kerosene heater to thaw it out to get it started.
