I Just leased on with a company and i have a real bad feeling about my truck,i picked it up from there local truck shop and the air horn did not work,the lube sticker on the windshield was not changed and the 6 of the tires ended up being bad or not legal.Now i have a noise coming from what i think is the throwout bearing when i push in on the clucth.They said (the local truck shop) that they did a PM & DOT Insp. but how can this be when i greased it today after only having it for 1 week and pulling only 3 loads.What do i need to do here please help me with this noise problem please.
Thanks
2000 Freightliner throwout bearing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bucku, Aug 16, 2008.
spike64 thanks for the reply i greased the bearing while the motor was running and it made the noise a lot better but my question is why is it making a noise when a push in on the clutch
because you are putting pressure on the bearing, It is wore out,get it replace while you can still make it to the shop tow bills are expensive.
make sure that the bearing gets greased after that, once it gets dry from lack of grease its too late to save it.Big Duker Thanks this. -
Its possible you may need a clutch brake. If you dont lube (or in some cases lube to much) the throwout bearing it will fail. But you need to check clutch adjustment and the clutch brake and see if it helps. If not you will need a throwout bearing
Noisy release bearings are actually fairly common on trucks in rough service or ones with negligent maintenance issues.It may last a long time like that.Try a good high-temp grease and service the release bearing while a helper works the clutch pedal with the engine running.
Thanks for all the replys,can you change the throw out bearing with out chaning the clutch? im being told it comes all in 1 package-check clutch adjustment and the clutch brake and see if it helps-it does not make any grinding noise when i put it in gear so i think it all ready as be adjusted.
