2001 FL112... No rear pass side turn signal... HELP!
Discussion in 'Freightliner Forum' started by C12RAT, May 6, 2014.
  1. C12RAT
    C12RAT Bobtail Member
    Hello All
    I have a 2001 FL112 with a C12. I'm pulling my hair out trying track down my passenger side rear tun signal source. Right now The main wire harness feeding the tail light sends power to the brake lights (Both sides) but does not flash (pass side) when the turn is on. The front signals work and flash as well as the dash but no flash in the rear. I'm using a meter and a test light...
    On a secondary trailer plug (Tucked under the truck at the rear) I get a turn signal but no brake light power.:biggrin_25510:
    Here is a picture of the plug that has turn signal power but no break lights...
    Does anyone know if the front and rear turns are on different circuits?
    So the main wire harness work for brake lights and driver turn but not passenger side turn and the plug only work for turn...
    Anyone out there that can help???
    Thanks a ton!
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Take the back off the plug and insp. wires for tightness.
  4. C12RAT
    Thanks baha!
    I have checked it, and everything is sealed up tight and clean on the plug. I was hoping there was a flasher relay for the rear turn signals that was not working.
    Going to put a toner on the wire and try to trace it back to the front of the truck.
    I was hoping someone was going to say "Sure, there is a relay for each rear turn signal, in this spot!" HAHAHA, so much for that.
    Thanks for the help.:biggrin_25519:
  5. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    A bad turn signal switch can cause that
  6. QUALITYTRUCK
    1,802
    1,763
    Jun 14, 2009
    romulus,mi
    hold up the turn signal lever (put pressure on it)
  7. C12RAT
    Thanks everyone.
    Looks like it is the turn switch...
