2001 International 4700 Brake question
Discussion in 'International Forum' started by Caleb12321, Dec 6, 2023.
  1. Caleb12321
    Caleb12321 Bobtail Member
    2001 International 4700 dt 466
    hydraulic brakes
    I replaced the brake pads all around. Compressed the calipers and fluid pushed out of reservoir "normal" and put back together and everything works great.
    The issue I am having is the brake pressure light will come on after driving and I go to stop. Once it's on it stays on.
    Everything is normal other than the light coming on. Brake motor comes on when truck is off and brakes are pressed, /when key is on and not running the brake motor runs like it should,
    Any idea? I have talked to a few mechanics and one told me to pull sensor off the side of master cylinder and see if I see a rod. It looks like the rod is touching the sensor and not in the right position.
  3. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Double check fuses F33 and F3.
