2004 Peterbilt 379 braking/turn signal issue
Discussion in 'Peterbilt Forum' started by Lunchbox714, Nov 7, 2021.
  1. Lunchbox714
    Lunchbox714 Bobtail Member
    6
    Everytime I step on the brakes the front passenger side turn signal and on the dash turn signal lights up solid. this only happens when the truck is charged with air. when truck has no air like in the mornings, I step on the brakes peddle and nothing lights up
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    regardless. that junction box at rear of truck is nasty and corroded. grounds are all f'.ed up.
    https://www.amazon.com/MICTUNING-Wa...t=&hvlocphy=9007357&hvtargid=pla-759801914040
  4. lester
    2,919
    7,876
    Jan 2, 2012
    NW, Iowa
    That's a good idea and I'm kinda mad I didn't think of it. Every year my rear S/T/T harness gets shorter and shorter.
  5. Don379
    714
    1,286
    Jan 7, 2021
    If your going to make the day out of it, get rid of all the old wires as well and run this duplex wire or triplex if you need 3 wire.
    https://www.amazon.com/Duplex-Tinned-Marine-Wire-Black/dp/B00MI52TA4
    To add new pigtails to lights, don’t bother using junk connectors ore solder iron. Watch a YouTube video on how to use these and then for added protection slide a shrink tube over them. You will have made yourself years of trouble free service.
    https://www.amazon.com/dp/B089D5GD4...=8g63u&ref_=sbx_be_s_sparkle_mcd_asin_1_title
