Morning,
Got a 2004 T8 with MXS CAT C-15. When you first start the truck the orange tank takes forever to build, once it hits about 110 psi the green tank shoots up fast, and the orange tank loses pressure pretty fast too. They catch each other at about 90 and build up together until the governor cuts out at 130. Once the governor cuts out the orange tank doesn’t lose air like it did before.
Thoughts? Thanks!
-Nathan
2004 T-800 Air build issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mountain_Dweller, Nov 11, 2019.
Leaky 2-way check valve between the primary and secondary tank possibly.
Air up truck to cutout, shut it off. Open the drain on the primary tank and drain it down to zero. Check gauges. If both read zero, check valve is likely shot. If primary is zero and secondary is still full, build air back up and repeat but drain the secondary tank this time. Secondary gauge should read zero and primary should stay full. If both are empty, likely the check valve.Dino soar, Tx Countryboy and Mountain_Dweller Thank this. -
Sounds like normal operation for an ADIS dryer. Snap a picture of your air dryer.
pushbroom, AModelCat and Mountain_Dweller Thank this. -
-N -
Might want to check hose from compressor all the way to air dryer. They tend to get hard and collapse. I usually disconnect the -10 hose off the compressor and air it up with shop air to isolate between compressor or hose issue.
pushbroom, Mountain_Dweller and AModelCat Thank this. -
Ok, I tried this test on both tanks and both tanks drained both times. Sure sounds like the check valve, eh?
-N -
Is this the air dryer you have?
pushbroom Thanks this. -
