2005 dt 466 fault codes. Anybody familiar with them
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by B77, May 29, 2020.
  1. B77
    B77 Light Load Member
    189
    89
    Dec 16, 2010
    I got 10 fault codes:
    639_14 A. 5 with this number
    241.254
    228.254
    4:240
    255:254
    192:254
    2023-14p. 150:1 and 150:2 and 150:9
    25:2. 612_14p. And 1:240. 639_14p
    Any pointers will be appreciated.
  3. Heavyd
    Heavyd Road Train Member
    7,767
    6,204
    Feb 4, 2009
    Looks like you are reading those from the cluster LCD display. Those are all body controller related with a lot of gibberish. 639-14 is datalink communication time out faults. 2023-14 is cluster losing communication with the engine. The codes you get from the cluster really shouldn't be used for troubleshooting and you need to get it properly scanned. Anything with a "p" after it is inactive. "A" is an active code. Not all active codes mean there is problem when the body controller is reporting it. This is why you need to get it properly scanned.
    spsauerland and B77 Thank this.
  4. B77
    189
    89
    Dec 16, 2010
    Correct, truck still doesn’t run. Was hoping for a lead where to look. Some are irrelevant yes.
  5. Heavyd
    7,767
    6,204
    Feb 4, 2009
    During cranking, if you do not see any engine speed on the tach, the engine ecm may not be booting up at key on based on the codes you have there.
  6. B77
    189
    89
    Dec 16, 2010
    That one stays on zero yes. Mechanic ended up with a defective ipr valve what didn’t got power also. But if the ecm doesn’t get power that valve doesn’t get power either
  7. Heavyd
    7,767
    6,204
    Feb 4, 2009
    The ecm controls the ground side. The ipr gets 12 volts at key on from the same source as the throttle pedal. So 12 volts there doesn't mean the ecm is powered up. Check the main 40 amp fuse at the batteries and connections. Follow the harness up to the engine and check for any spots where it is rubbed through. There is another connection near the starter that may be corroded or melted.
  8. B77
    189
    89
    Dec 16, 2010
    I followed the wiring up to the starter. But not what is on top of the starter yet. I am getting a guy with a laptop first
    Heavyd Thanks this.
  9. Heavyd
    7,767
    6,204
    Feb 4, 2009
    Laptop is pretty much the first tool we grab anymore.
  10. PASBREE_Logistics
    PASBREE_Logistics Bobtail Member
    If this is for a DT466 the correct answer for shutting off while driving and stahling & 6 out of 10 of the times it will be (MILLION DOLLAR REPAIR VALUE ANSWER). IDM RELAY.
    - its not your injectors
    - its not the fuel filter
    - its not the ICP, IDP, high pressure pump
    - its not crank shaft sensor
    - its not the manual pump
    - its not air in fuel lines
    UNDER THE HOOD FUSE BOX PULL OUT THE IDM RELAY, replace with New & buy a dozen cause your not home free yet. whatever is shorting it out or power surging the relay IS THE PROBLEM THAT NEEDS TO BE FIXED, but my solution will save you thousands of $ in parts, labor, tow, loss of work, embarrasment
    I HOPE YOU ALL FIND THAT HELPFUL
    DONATIONS ACCEPTED
    HOW MANY PEOPLE ARE RUNNING INTO THIS PROBLEM AND REPLACED EVERYTHING AND STILL SAME CAUSE ITS THE RELAY!!!!!!!
    i just spent over $6,000 to learn this trick & im passing it along to my DIESEL TRUCK DRIVERS
