2005 dt 466 fuel pump priming
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by B77, May 29, 2020.
  1. B77
    B77 Light Load Member
    189
    89
    Dec 16, 2010
    Hello, I can’t get the pump to prime the lines. The hand primer it self works good. I put the fuel tank suction line in a bottle with diesel and all it does is blowing air in it instead of sucking it. Any ideas what is wrong. No leaks as far I can see smell or hear in the system.
    I took the hand primer of finger in the hole and it gives good suction
  3. B77
    189
    89
    Dec 16, 2010
    This issue is fixed. Not sure how to delete this post
  4. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    You dont have to delete it.
    Tell everyone what you did to fix it?
    PE_T, spsauerland, lwlevens and 2 others Thank this.
  5. B77
    189
    89
    Dec 16, 2010
    Cleaned out the hand primer. What was leaking a little more than I thought.
    PE_T, BoxCarKidd and Heavyd Thank this.
  6. Inderjit
    Inderjit Medium Load Member
    625
    609
    Sep 17, 2017
    There is an updated hand primer. The earlier version was prone to leakage.
    PE_T Thanks this.
  7. PE_T
    PE_T Road Train Member
    If the hand primer uses o-rings, perhaps it just needs new ones. I’m reading that the bottom part of the hand primer that functions as a plunger can get damaged. If so, you’ll need a new hand primer.
