2006 dt466 egr low power low boost
Discussion in 'International Forum' started by saml.burris14, Feb 28, 2023.
  1. saml.burris14
    saml.burris14 Bobtail Member
    6
    Please read full post before replying! Thank you!
    My problem:
    1. Lacking power on takeoff/ struggles to get up to speed. Cant get over 45-50
    2. Low boost reading low for what it should be according to manual
    3. Exhaust back pressure reading weird on scanner. Engine will run noticeably different if unplugged.(check engine light comes on when unplugged)
    Parameters:
    • Engine: dt466 egr 245hp (not dt466e was after the “e” version and before the maxxforce)
    • Turbo: Vgt s300 series (fresh overhaul, engine had running issues prior to turbo over haul)(also spins freely)
    • ICP @ idle: actual~800, scanner~800
    • ICP @ WOT no load not driving: actual~2800, scanner ~2800
    • ICP @ WOT loaded not driving: actual~3500, scanner~3500
    • ICP @WOT loaded while driving: actual~4000, scanner ~3900
    • Boost pressure loaded while driving: actual 15 scanner 17-19
    • Fuel delivery pressure @ idle: actual ~56 scanner 56
    • EGR: blocked off for diagnosis
    • Boost leaks: no (pressure checked charge air cooler with piping)
    • Exhaust back pressure @ idle: actual~0 scanner ~12
    • Exhaust back pressure loaded not driving: actual 25 scanner ~35
    Tests completed:
    • Tested voltages at EBP connecter all passed
    • Tested resistance at EBP connector all passed
    • Turbo passes bounce test
    Dtc codes: no engine codes. Does have body codes but i think are irrelevant?
    Shop manual with specs: Navistar International DT 466 Diagnostic/Troubleshooting Manual (Page 608 of 658) | ManualsLib
    need help this is stumping me pretty bad.
    Thank you for any help!
    -Sam
  3. Flint1
    Flint1 Road Train Member
    1,143
    9,805
    Sep 4, 2019
    Alberta
    Check and see if it has a catalyst muffler. They didn't have a dpf, but they were equipped with sort of a catalytic converter inside a normal ish looking muffler. Mine had "catalyst" embossed on the shell. They tend to face plug, especially if before the engine repairs it was burning oil or coolant.
    The grid heater is also prone to plugging (if equipped). I disassemble ours from time to time to clean them. I've had them blocked to the point the intake was pushing air thru a hole the size of a walnut.
    If there is a thumping noise thru the intake inspect the valvetrain. The dogbones that align the lifters break, the lifters turn and wipe out the cam.
  4. saml.burris14
    6
    @Flint1
    Runs the same with exhaust removed.
    Engine is completely overhauled
    Grid heater is clean
  5. Flint1
    1,143
    9,805
    Sep 4, 2019
    Alberta
    Does the VGT do a bounce test on key on?
    Can you manually move the vgt lever and have it bounce?
  6. saml.burris14
    6
    @Flint1
    Yes turbo passes bounce test.
    just a heads up this is stated in the original post
  7. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    Can you post the last eight of the VIN or PM it to me? What is the fuel pressure under load?
    Remove the filter cap and filter and have a look down inside the filter housing. Is there lots of
    rust and grit around the bottom of the housing? If so clean it out well there is also a strainer
    under a screw on cap on the bottom of the filter housing clean that as well. The dirt and rust
    get into the pressure regulator/orifice and cause the pressure to drop. 56 PSI is a little low
    if I remember correctly.
    At the bottom of the inside of the filter housing towards the rear of the engine you will see a
    shiny little orifice. Take 7mm allen socket and remove it and blow it out and put it back in.
  8. saml.burris14
    6
    @Inderjit
    Tank is pretty clean
    On the spec sheet supplied it state’s minimum fuel pressure of 50
    Under load it only drops a few psi at most
    The vin is
    1HTWBAAN07J421227
  9. Flint1
    1,143
    9,805
    Sep 4, 2019
    Alberta
    Well you've gone thru my usual suspects with those.
    How far into the engine were you?
    If the gear train was apart any chance it's out of time?
    Overhead all good?
    The ole rag in the CAC ?
    You are in the realm of the weird.
  10. saml.burris14
    6
    @Flint1
    Full out of frame over haul.
    As far as being out of time, engine starts and runs to full rpm with no problem.
    doesnt fire out of intake or exhaust
    Compression is even sounding when cranking
    Blow by is at a pretty normal amount
  11. saml.burris14
    6
    @Flint1
    Never block cac with a rag when removed.
    How would you check if there was restriction?
