2006 peterbilt 379 with acert motor having power issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lokahi117, Nov 7, 2013.
  1. lokahi117
    lokahi117 Light Load Member
    86
    7
    Oct 7, 2012
    Also most of my runs are short only a few miles, and they are in dirt roads less than thirty miles per hour. And i didn't even notice the issue of power until I took my beast back onto the highway loaded.
  3. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    That sensor is a common failure. It is on the right side of the motor right next to the first valve cover. The big solinoid is not what your looking for it is the one next to that solinoid standing straight up next to valve cover. Unplug it take it loose with a socket put a new o-ring on the threads tighten it up plug in and your good.
  4. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    Sounds like the harness or actuator. When the harness on my Acert gave out, it struggled to get to 55. Yet, once I got it to highway speed, all was good. It would jerk all kinds of crazy b4 it smoothed out. You will get a "bad injector" code. I moved injectors around in order to see if the code followed the injector(s) due to the common power per 2 cylinders. It takes a few good steady hours to swap out the harness. There are a few discussions on the Acert injector harness when you do the search.
    lokahi117 Thanks this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Intake actuation pressure sensor is the cause of that flash code 95% of the time. It could also be wiring or a few other things. I'd replace the sensor. In the slim chance that it's not the sensor, you'll have a spare on hand, it wont go to waste, they do fail.
  6. bstromback2002
    bstromback2002 Light Load Member
    133
    24
    May 12, 2012
    wi
    You need to see what the code is first!!! It could be just a bad iva ( intake valve actuator) and the engine has went into limp mode meaning it probably has cut power by maybe 25% or maybe more!!! Also there is not a egr valve on these motors.
  7. bstromback2002
    133
    24
    May 12, 2012
    wi
    To view engine codes= turn cruise switch to off then hold the set/resume switch to either position until the engine light lamp begins to flash then release the switch. The lamp will then flash the first digit of the code and will pause for a second the flash the second digit of the code I have the factory service manual with me all the time so if you get the codes post them and I or someone else can tell you what they mean.
  8. lokahi117
    86
    7
    Oct 7, 2012
    It was a code fault 95 and I moved this one to the main truck garage forum since I realized an acert can be a bunch of different truck brands. So if a moderator wants to merge these two that would be ok. If not guys I'm still intersted in hearing your thoughts. The harness has been suggested by a few so I'm thinking about it but the Iva is what the code is saying so I'm gonna try to perhaps dig into that but there is no shop here so I'll be doing the work in a dirt lot. Lame.
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,115
    May 19, 2011
    Merged them for you.
  10. lokahi117
    86
    7
    Oct 7, 2012
    Is this sensor on some sort of fuel rail or oil rail, or is it threaded directly into the block? How will I know which one is the sensor is? And is there multiple sensors or is there just one? I will call peterbilt tomorrow morning and see how much this part is and might just try to replace it and see if that fixes it. Also how hard of a job is this? Thanks again so much my fellow overworked underpaid and under appreciated brethren.
  11. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Gear head and grape ape nailed it.
    Should be around $140 for the pressure sending unit. Front passenger side , top of the motor, kinda like a big spark plug with a harness ( 2 wire I think ) plugged into it. Screws in vertically.
    You need a tiny little o-ring also.
    Very simple job, you'll only leak a few drops of oil.
    %95 that this is your problem but it shouldn't derate your motor so I'd definitely pick up some filters while your at it... sounds like your fuel filter is screaming at you...
    Also shouldn't cause any damage if you can't get there this second but I wouldn't take any longer than necessary in case you have something else going on..
