hello guys I have a 2007 Freightliner century dd engine. 10 speed Eaton fuller today I was trying to put the truck in first gear. But all of a sudden the clutch pedal became kind of hard and the transmission just grinded and wouldn’t go into gear. Any thoughts of what the problem might be thank you.
2007 Freightliner century with Eaton fuller clutch problems
Discussion in 'Ask An Owner Operator' started by Moephilly1, Sep 23, 2018.
Typically I would say your clutch brake needs an adjustment which is easy but you are saying that your clutch pedal went hard. The first thing you will want to do is remove the clutch inspection plate. Have some one work the clutch back and forth while you see what’s going on in there and see if something looks a miss while they are working the clutch
Cam Roberts Thanks this.
Starting to think bushing came apart on clutch linkage from pedal to the trans. Not allowing pedal to be depressed all the way to engage the clutch brake. Would also explain pedal getting hard
How many little pieces of metal fell out when you removed the inspection plate?
iv had the same thing happen basically a spring broke and wedged itself in the clutch.
Hulld, Xzachtly and whoopNride Thank this. -
