Hey guys when my air is low only the warning light comes on no alarm. I don’t want to get a ticket for that therefore I want to change it
2007 w900 air buzzer Location
Discussion in 'Kenworth Forum' started by Moephilly1, Nov 30, 2018.
You might get the info you need if you post this in the Garage section
d o g and Moephilly1 Thank this. -
If the light works you don't need the buzzer.
probably not even a buzzer on the truckMoephilly1 Thanks this. -
The warning buzzer is part of central instrument cluster/ tach speedo head module. Should ding when you first turn key on as part of self test and tach and speedo will sweep. The alarm will only sound when engine is RUNNING. From manual:
AModelCat Thanks this. -
I've had cops check for the dinger. Besides the light.
And yes. My 07 w9 dings with the lights. And I don't think the engine needs to be running. On mine anyways.
