2009 Freightliner Cascadia ..Intermittent throttle ..(engine light .throttle drops out)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Anza Trucker, Jan 12, 2017.
  1. IH Truck Guy
    4,383
    50,150
    Mar 2, 2008
    Purgatory
    Wiggle the wire coming out of the pedal and see if you can get it to act up.
    Anza Trucker Thanks this.
  3. Anza Trucker
    Anza Trucker Bobtail Member
    13
    4
    Jan 20, 2014
    Okay ...FIXED! ...first ..let me thank all of you who responded ...although the tips that were supplied by all of you were not the actual cause of the problem here .. they were very helpful in eliminating un-needed steps ..as troubleshooting these types of issues can be a pain in the rear ..I did remove the accelerator assy ..and checked the TPS (throttle position switch) ..cleaned the switch with some contact cleaner ..re-assembled ..no joy ..
    FREIGHTLINER SERVICE KIT: P\N 23539639 DD PLATFORM DELTA PRESSURE SENSOR
    so ...what I didn't realize in my original description was that the accelerator did actually work ..but their was a 3-5 second delay in the action of the throttle when depressed ...so ..when stepping on it ..and not knowing the issue ..I just assumed the throttle did not work ..not keeping the peddle depressed for the 3-5 seconds need to get action out of the motor ..moving on ..
    ..the issue is EGR related ..the sensor assy mounts on the EGR feedback tube which feeds the intake system ..
    removing the old sensor ..exposed the two venturi ports ..(cleaned them ..a common pipe cleaner works fine) ..and installed the new sensor .....the kit comes with a new connector assy ..I did not change that as the integrity of the old connector was still very good ..
    ..so ...after installing the kit ..fired it up ...engine light out ..accelerator working fine ..thanks again to all ...this forum rocks!
  4. IH Truck Guy
    4,383
    50,150
    Mar 2, 2008
    Purgatory
    thanks for the update.
  5. Trying2makeit
    Trying2makeit Bobtail Member
    Did you ever find out what the issue was I am having the same issue now on my 2014 freightliner cascadia
  6. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
  7. north60
    north60 Bobtail Member
    43
    25
    Jun 13, 2019
    IF the egr delta p sensor doesnt fix it, check the little holes going to the sensor on the EGR venturi, they are famous for plugging up. so much fueling is based on the EGR delta p sensor on those detroits
  8. Demond123
    Demond123 Bobtail Member
    Hey did you ever figure out the issue I’m having the exact same issue right now
  9. Demond123
    Hey did you ever figure out what the problem was I’m dealing with the exact same thing right now
