2009 freightliner problems
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by 09freightliner, May 20, 2024.
  1. 09freightliner
    09freightliner Bobtail Member
    I have a 2009 freightliner 60 series 14l, I have had bad lack the last 4 months, it started with replacing the ECM and replaced engine and injector wiring harness, when I drive the rpm’s drop down to zero and starts bouncing up and down, it does slows the truck to 30pmh, I have to several shops and nothing. Sometimes I can drive for more than 8hrs with no issues and all of a sudden it starts again.
  3. Pepper24
    Pepper24 Road Train Member
    2,054
    1,563
    Dec 3, 2010
    I feel for you.My dad had a truck that would just start losing oil pressure going down the road and cut off 6 different shop no one could figure out why finally just traded it.All the emissions and sensors,computers on truck’s make it a nightmare when it goes wrong shops are helpless if they can’t see the problem on there laptop and other than just throwing parts at it and charging you out the wazoo there’s nothing to do.Good luck when someone finds the problem let us know what it was.
    navypoppop Thanks this.
