2009 MaxxForce 7.6l Coolant and Oil Mixing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by itsbroken, May 29, 2023.
  1. AModelCat
    161,121
    Coolant and oil churned together usually gets milky or they stay separated. If its sat a few weeks without running and you dropped the oil the coolant will drain out first.
  3. itsbroken
    itsbroken Bobtail Member
    7
    That is what I thought as well. No coolant came out, and I ran it afterwards and the oil looked normal, no milky color. So, signs are pointing to a bad oil cooler since I am only seeing oil in coolant, not the other way around.
  4. itsbroken
    7
    Conclusion: I had Blackstone analyze the engine oil, they found no coolant. I am almost certain the oil cooler was the problem. Had a reasonable offer as-is, so the truck is sold. Thank you to those that took the time to respond!
