2010 kenworth Cummins isx too much white smoke coming out of muffler
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Dec 15, 2020.
  1. Gurjap
    Gurjap Light Load Member
    55
    11
    Mar 18, 2020
    Hello friends,
    I have a 2010 kenworth t800 with a Cummins isx and I have cleaned it’s dpf filter just recently. However there are times where so much white smoke comes out my muffler and then stops and comes back sometime later. In a 10-12 hour drive it will have white smoke around 3 times for around 1-2 hours each time where the smoke comes out in 2 second bursts.
    Any help will be great!
  3. TripleSix
    124,829
    Any coolant losses?
    Gurjap and magoo68 Thank this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,383
    Jun 11, 2011
    st malo mb canada
    If it’s not using coolant ,Sounds like it’s doing a regen I’d look at the 7 th injector .
    spindrift, firemedic2816 and TripleSix Thank this.
  5. AModelCat
    145,376
    They cleaned the DPF but how was the catalyst ahead of it (the DOC)? When the catalyst starts to fail it will start to smoke white I believe.
    Flint1 Thanks this.
  6. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    832
    990
    Nov 23, 2014
    Grants Pass, OR
    I've heard that is also a symptom of a bad def doser valve
    Gurjap Thanks this.
  7. Dave_in_AZ
    315,827
    Take it to Cummins, not a dealer.
    Gurjap Thanks this.
  8. Gurjap
    55
    11
    Mar 18, 2020
    Hello sir,
    where is the DOC located and how does it look like?
  9. Gurjap
    55
    11
    Mar 18, 2020
    No sir no loss at all
  10. AModelCat
    145,376
    It looks very similar to the DPF and it should be mounted just ahead of the DPF (exhaust should flow through it first, then into the DPF).
    Gurjap Thanks this.
  11. Eddiec
    Eddiec Road Train Member
    1,931
    2,802
    Feb 2, 2015
    Gurjap Thanks this.
