2010 maxxforce can't get power steering to work
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jhncp, Feb 22, 2020.
  1. Jhncp
    Jhncp Bobtail Member
    41
    Feb 4, 2020
    I just replaced seal in ps pump and installed, and yes I have adapter coupler installed (new one, old one mysteriously vanished) and nothing yet. I'm guessing it needs to be primed/bled. I have front end jack up and keep turning but nothing for hours.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Did you crack open lines at steering box with eng. off and wait for p/s fluid to come out?
  4. Jhncp
    41
    Feb 4, 2020
    I just cracked both lines with engine running but still no luck
  5. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Are you getting p/s oil running out of line at steering box with motor off?
  6. Jhncp
    41
    Feb 4, 2020
    Yes the big line it runs out like crazy by pump and reservoir runs to it directly. Filters to or from steering box. I need to get more fluid because I kicked the container over by accident. You would think when I crack smaller line it should leak like crazy from pressure but isn't. Hope I don't have to take pump back off.
  7. Jhncp
    41
    Feb 4, 2020
    I took pump back off and frustrated af. I took pump apart again and determined I must not have it back together right but I have no idea how to fix it.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,461
    6,503
    Aug 26, 2014
    Lay it out and send pictures. Best to mark everything before disassembly.
  9. Jhncp
    41
    Feb 4, 2020
    The only thing I can see that I could of mixed up is plates pin position. I assume brass color faces rotor
  10. Jhncp
    41
    Feb 4, 2020
    Thanks for all the help. I studied witness marks on parts and got it work.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Good lord.
    Hurry up, take my monah!!! fix me!! you rule!
    The parts whisperer, fixing trucks based on previous scrapes and marks.
    If you have it together maybe you can write out a note reminding thsoe of us who may have forgotten or possibly teaching those of us who escaped from kindergarden to try and play with the big kids without knowing how. +)
