2010 prostar maxxforce 13 no power/speed
Discussion in 'International Forum' started by grandpa joe 71, Jul 9, 2016.
  1. grandpa joe 71
    grandpa joe 71 Bobtail Member
    36
    Oct 31, 2015
    I could only wish right now I spent 2800 in diagnostic fees and parts at 1 dealer and so far about 5 at this one
  3. Texnmidwest
    Texnmidwest Light Load Member
    282
    428
    Mar 6, 2015
    Heck, you could be better off buying a new truck if that keeps up! :(
  4. grandpa joe 71
    36
    Oct 31, 2015
    I know the first dealer hosed me this seems ok they didn't charge me me for the miss diagnosis
    Rlequire Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    We don't change too many fuel pumps anymore. Fuel pumps are easy to check with the right tools. In servicemaxx you can see the pressures and how the pump is commanding itself to achieve those pressures. During a hard pull the fuel rail will reach 32000 psi. The engine will command this and also measure actual pressure. You can plot a graph and watch rail fuel pressure desired against actual and it better match. Normally they do. If the pump is bad the actual will always be lower slightly than desired. Also you can see fuel delivery pressure which is normally around 90 psi. Lastly you can see fuel pressure control percentage. The harder the pump has to work, the lower this percentage goes. Anything under 25% duty cycle means the pump is working harder than normal to achieve the fuel pressures desired. This literally takes 25 seconds to review after recording a 0-60 snapshot.
    2013Maxx and QUALITYTRUCK Thank this.
  6. Texnmidwest
    282
    428
    Mar 6, 2015
    With my truck, the fuel pressure was a fraction of what you state. Changing the fuel pump on my 2013.....the second time did the trick. Might have just been an anomaly.
  7. Heavyd
    7,804
    6,253
    Feb 4, 2009
    The low pressure fuel pump is piggy backed on the high pressure pump, so unfortunately any low pressure system problems does mean the whole pump has to be changed which sucks.
    Texnmidwest Thanks this.
  8. grandpa joe 71
    36
    Oct 31, 2015
    On mine the exhaust gas pressure sensor they say computer has not recognized it yet have to do a minimum of two regen and reach 50 mph
  9. Heavyd
    7,804
    6,253
    Feb 4, 2009
    Do you mean the DPF differential pressure sensor?
  10. grandpa joe 71
    36
    Oct 31, 2015
  11. grandpa joe 71
    36
    Oct 31, 2015
    Here is update dealer couldn't figure it out computer is still calling for soot load level to high needs to regen and Navistar won't help anymore due to dpf being aftermarket Navistar says if I don't have theirs they can't help dealer I don't understand it anymore dealer can't figure this out
