2010 prostar maxxforce 13 no power/speed
Discussion in 'International Forum' started by grandpa joe 71, Jul 9, 2016.
  1. Bigjas
    Bigjas Bobtail Member
    Where are you located Heavy D I have questions regarding my truck but I think I'd rather just bring it too you.
    You have more answers than anyone else I've' spoken with. My problem is intermittent and of course when it's in the shop it doesn't duplicate the problem.
    Low power, low speed it may not do it for days at a time. When it does I'll flash the key off and back on real quick that seems to clear up the problem which allows me to drive it somewhere safe to wait for it to begin to drive properly.
  3. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
  4. Truckers Report Jobs
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    I would check it for codes and go from there. I would also road test it and record a 0-60 snapshot to see how it is performing. Intermittent problems are tough. This is when the guessing game starts.
  6. JONBOY1713
    JONBOY1713 Bobtail Member
    2014 maxxcrap lol new injector harness replaced only #6 injector replaced high pressure turbo cause turbin was shot … Also replaced oil pressure sensor cause it was reading nothing on my scanner snap on prolink ive cleaned all grounds an positive wires etc cleaned lots of other sensor pig tails also
    no throttle response or and the oil pressure gauge does not work what should I do next ????
  7. JONBOY1713
    also only active codes I have are
    SPN 3509 FMI 4
    SPN 100 FMI 4
  8. Bludhini
    Bludhini Bobtail Member
    Purchased a 2010 prostar I spent a lot to get it right. I just replaced crankcase breather. Now I am losing power. The crazy thing is it's a small amount of power. The only problem I have is on the up and up hills. The warn engine is on but it goes away when I turn key on and off. For awhile the power is back on but if I push in pedal engine warn is back on. Hopefully someone can help thanks
  9. Heavyd
    7,804
    6,253
    Feb 4, 2009
    You need to get it scanned to see what fault it is logging.
  10. Young_simba
    Young_simba Bobtail Member
    13
    4
    Jun 28, 2019
    Test
  11. Wmendoza
    Wmendoza Bobtail Member
    I am having issues with my maxxforce when carrying heavy load wont go over 65 mph?
  12. Kacho24
    Kacho24 Bobtail Member
    4
  13. Kacho24
    4
    Hello I have the same problem which little hose ? Because the air control valve have 2 hoses
