2011 Mack MP7 Rough idle, low power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by springerj, Dec 30, 2021.
  1. springerj
    springerj Bobtail Member
    10
    May 13, 2014
    I’ve got a 2011 Mack with an MP7 in the shop with a rough idle, jumping between 600 and 650 RPM and low power. Truck has no fault codes. It’s gotten a new EGR pressure sensor, EGR valve, Fuel pressure relief valve, fuel filters. EGR cooler was clean when checked. Removed and checked for debris in fuel lines going to ECM cooling plate. Fuel pressure jumps around between 50 and 60 PSI at idle.
    Any ideas?
  3. cke
    cke Road Train Member
    5,937
    73,020
    Aug 4, 2013
    Colfax Wi
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    No clue. That one's the Volvo D11 engine.
    @springerj go over to big Mack trucks forum they'll be able to help. A few Mack techs are regulars over there
    springerj Thanks this.
  5. springerj
    10
    May 13, 2014
    Will do, thanks.
    Brettj3876 Thanks this.
