2011 Volvo vnl780 TCS & ABS losing throttle & power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Volvo_780, Feb 22, 2021.
  1. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Is it immediately pops up afret truck start rolling or randomly?
  3. Volvo_780
    Volvo_780 Bobtail Member
    26
    Feb 22, 2021
    Randomly like today when I picked it up from the shop I drove about 30 miles and it started to act up then when it does act up it hard to drive since you lose throttle
    Snailexpress Thanks this.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Most likely you have wiring problem like many other Volvo owners.
    I'll start from cleaning all grounding connection as the bad one can cause unpredictable codes.
    Ground cable from battery to starter, ground cable from battery to cab pass thru (they are under air tubes).
    Ground cable from battery to frame. This one has fusible link under shrink tube on the frame side. Need to check with ohmmeter.
    And Bendix diagnostic to check the ABS module itself.
    Volvo_780 Thanks this.
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If you are in Salt Lake City I can help you tomorrow.
  6. Volvo_780
    26
    Feb 22, 2021
    Thank you so much I am gonna have the mechanic read your message and check since you know what your talking about
  7. Volvo_780
    26
    Feb 22, 2021
    Man I wish I was can I get you a flight ticket to Michigan lol
  8. Volvo_780
    26
    Feb 22, 2021
    man any way I can talk to you on the phone to explain cuz your the first person that is making sense
  9. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    You need more electronic technician to find Volvo gremlins.
    More information for your mechanic you can find on Bendix web page. They have very good PDF for EC-60 ABS module with code troubleshooting and pinout diagrams.
  10. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    I'll PM you.
