2012 Cascadia Engine Brake Q
Discussion in 'Freightliner Forum' started by double yellow, Oct 30, 2011.
  1. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Is there a way to activate the engine brake without applying the service brake? I just see the 3-position toggle switch on the dash, and the button on the wheel, but it seems that I have to press in the brake pedal about 1-1.5" before the engine brake will kick on. This is annoying since that much brake application slows the truck fairly dramatically and I'm usually only wanting the engine brake to maintain my speed down a grade...
    I know that once I get ~5mph above my cruise control set-speed the engine brake will come on without any service brake application -- I'm just wondering how I can do that when not on cruise...
    Thanks,
    DY
  3. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Are you disengaging the cruise control when you hit the brake pedal?
  4. Sparkz
    Sparkz Light Load Member
    76
    16
    Jul 10, 2011
    New Zealand
  5. THBatMan8
    THBatMan8 Road Train Member
    1,478
    469
    Feb 13, 2011
    Wherever I park
    You might still have the cruise control on. You'll need to turn it off.
    If not, it's tuned by the trucks ECU. You can take the truck to a dealer and have them change the settings. I actually prefer to have a engine brake engage this way. I cant count how many times I forgot to turn off the engine brake, and wonder why the truck was dropping RPM's like a ex-gf when I was accelerating.
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Cruise is inactive when it is doing what I don't like
    dd15
    thanks, I'll double check that cruise master is off, but I'm pretty sure it is.
  7. Sparkz
    76
    16
    Jul 10, 2011
    New Zealand
    Jakes should come on automatically as soon as the throttle pedal drops back to the idle position when not on cruise.
    I would guess that a parameter is not set correctly in the CPC(cab ECU). They can be a bit of a pain to set up correctly. May need to use DRS, not DDDL7 to change the parameter.
  8. Sparkz
    76
    16
    Jul 10, 2011
    New Zealand
    The CPC parameter is PGR010/004. Should be set to "0. Disable". Yours is probably set to "1. Enable automatic engine brake with service brakes".
    Can be reset with DDDL7.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Nice info, Thanks
  10. fgb3
    fgb3 Light Load Member
    112
    36
    Nov 2, 2011
    elba ny
    ya hes prolly right i have the dd15 and mine works fine.must be set up wrong
